Posted: Mon Jul 20, 2020 1:12 pm Post subject: Re: Can basic clock change to MFD
I think the ports are not matching. My display only having clock with one single bulb. It doesn't have the single line date and time on it. Do you think the ppt30 or ppt 40 ports are available other than the socket shown in the clock.
Appreciate your answer.
gazza82
Posted: Mon Jul 20, 2020 7:53 am Post subject: Re: Can basic clock change to MFD
If you swap to the correct type .. there are two. 3 and 4 bulb versions. You can't swap between the two so check your unit first.
Not everything may work as they need to be activated using PP2000. I converted my 2002 to the more complex version but have yet to get the outside temp to work even though it may have a sender in the door mirror.
nuwan
Posted: Sun Jul 12, 2020 7:13 am Post subject: Can basic clock change to MFD
Hi all,
Can basic clock be changed to Mfd?
This is the same what I have right now in my 206. (2006 XR with com2000)
