Latest: tbafonso
Overall: 17130
Online Now [259]:
Visitors: 258
Today: 28101
Total: 103144879
Forums › Tuning, Modification & Legal › Project Cars › Jamie: GTi180
Jamie: GTi180
Go to page Previous  1, 2, 3 ... 27, 28, 29 ... 43, 44, 45  Next
Daniel206RC
PostPosted: Wed May 26, 2010 2:40 pm Up
how big spacers did you buy?
03, RC / GTI180
03, SW XSI
Jamie
PostPosted: Wed May 26, 2010 2:41 pm Up
10mm, thinnest hubcentric I could find!
Daniel206RC
PostPosted: Wed May 26, 2010 2:44 pm Up
would fit fine then Smile you are running standard size discs?
03, RC / GTI180
03, SW XSI
Jamie
PostPosted: Wed May 26, 2010 2:47 pm Up
yep
Jamie
PostPosted: Thu May 27, 2010 10:29 am Up
Just got off the phone to RallyDesign, wasn't impressed, they weren't very helpful, maybe because it's close to clocking off time...
Anyway, I want to order a set but am a little lost as to what exposed length I'd need...
I have TD Pro Race 1.2 and will be using a 10mm spacer to clear the Brembo's... any ideas?
I am also pretty sure I know which nut I need, but again would rather check. My wheels need tapered nuts, so will these do the job;
www.rallydesign.co.uk/...ts_id=4650
Any help much appreciated Smile
Jamie
PostPosted: Fri May 28, 2010 1:55 pm Up
Topmounts;
Should be on track at FCS now, got some Pagid pads coming from Kam Racing for the time being until they can deliver the CL Sad
Jamie
PostPosted: Tue Jun 01, 2010 4:02 pm Up
Booked in with Kyle this weekend for a full brake change and service, as well as installing the Grp N topmounts and Grp N engine mounts.
This should mean I'll be on track at FCS, and I've booked a trackday at Llandow on the 19th June!
£80 for a full day open pit, bargain!
PostPosted: Tue Jun 01, 2010 4:15 pm Up
What do Group N engine mounts consist of? Group N to me can be very misleading because it suggests 'showroom class'.
I'm always suspicious of anything that's described as 'stage 1/2/3, group N/A, motorsport' etc.
Peugeot Sport do uprated mounts for the 206...Vibra Technics do them as well but they are simply described as road and motorsport use.
Jamie
PostPosted: Tue Jun 01, 2010 4:18 pm Up
I have the Vibratechnics lower mount & gearbox mount, and the Baker B&M ECU side mount.
spike_202
PostPosted: Tue Jun 01, 2010 4:22 pm Up
i need some new engine mounts, were did you get yours from jamie?
**spike's project**
TEAM:+200bhp
Jamie
PostPosted: Tue Jun 01, 2010 4:23 pm Up
Vibra Tachnics direct & from Baker BM Wink
spike_202
PostPosted: Tue Jun 01, 2010 4:29 pm Up
i see,how much are they for the differnt mounts?
**spike's project**
TEAM:+200bhp
Jamie
PostPosted: Tue Jun 01, 2010 4:32 pm Up
I think I paid about £130 for all 3...
Jamie
PostPosted: Fri Jun 04, 2010 8:25 am Up
A lot of money's worth of brakes!
CL RC5+ pads (front & rear)
Maxtorq Grp N discs (front & rear)
Brembo 4 pot calipers (front)
Braided Hoses (front & rear)
CL DOT 4 brake fluid (1L)
Danw_VVT
PostPosted: Fri Jun 04, 2010 8:30 am Up
when ever you decide to sell come my way Very Happy
Page 28 of 45
