Posted: Thu Aug 12, 2010 7:32 am |
Fitting my new susspension this weekend, got all the kit i need finaly, and a mate.
wheres the best place to jack up the front and back with a trolley jack so i can get the axel stands under the sill jacking points. ?
| 1992 White 205 Rallye - S2 Engine
2000 Saxo VTS MKII - Silver - For Sale | |
Posted: Thu Aug 12, 2010 7:34 am |
I jack it up using the points that you want to put axle stands under.
Posted: Thu Aug 12, 2010 7:36 am |
Without much knowledge I do the rear on the part next to the shocks (attached too the frame) and on the fron't on a small plate just inwards of each of the springs. Never had a problem with them.
Posted: Thu Aug 12, 2010 7:40 am |
I always try to jack it up under any strong part of the chasis and then put the axle stands under the subframe close to where the wishbones are mounted, as ive found the sill jacking points are a bit flimsy. Not sure where to jack it up under for the rear though so would also be interested in where people do.
Posted: Thu Aug 12, 2010 8:30 am |
Posted: Thu Aug 12, 2010 12:41 pm |
cheers.
Posted: Thu Aug 12, 2010 12:50 pm |
Hate the fact my trolly jack doesnt fit under the car until I lift it a bit with the stock jack - and i dont even consider my car particularly low. Maybe my jack is just masseeeve.
Posted: Fri Aug 13, 2010 11:12 pm |
Locky wrote: |
Hate the fact my trolly jack doesnt fit under the car until I lift it a bit with the stock jack - and i dont even consider my car particularly low. Maybe my jack is just masseeeve. |
I go under the front bumper of the car and jack up on the subframe. with this
www.machinemart.co.uk/...olley-jack
| Peugeot 206 GTI 180.
Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere. | |
Posted: Sat Aug 14, 2010 1:16 am |
Locky wrote: |
I used to drive up on a block of wood befor I could get the jack under.
Posted: Sat Aug 14, 2010 5:53 am |
NorthantsBen wrote: |
Locky wrote: |
I used to drive up on a block of wood befor I could get the jack under. |
i'm having this problem as well so thats a good tip
Posted: Sat Aug 14, 2010 5:57 am |
DeadEyePaul wrote: |
Locky wrote: |
i'm having this problem as well so thats a good tip |
Failing the wood, an Argos catalogue works spot on as well!
Posted: Sat Aug 14, 2010 6:03 am |
Locky wrote: |
Same with my 306
Posted: Sat Aug 14, 2010 6:13 am |
[quote="tomd0801754"]
Locky wrote: |
Quote:: |
Failing the wood, an Argos catalogue works spot on as well! |
wahoo thanks again
Posted: Sat Aug 14, 2010 7:31 am |
tomd0801754 wrote: |
Locky wrote: |
Oo nice ideas. Suppose a brick would do the trick too.
Posted: Sat Aug 14, 2010 2:07 pm |
Locky wrote: |
Locky wrote: |
Oo nice ideas. Suppose a brick would do the trick too. |
Yep decently does
:). Done that once ir twice too
