Latest: S2cgm
Overall: 17178
Online Now [115]:
Visitors: 114
Today: 17193
Total: 136339150
Forums › The Car › 206 Talk › angel eyes
angel eyes
saiefovech
PostPosted: Wed Aug 25, 2010 4:52 pm Up
heelo guys ,, found this angels in ebay
cgi.ebay.com/206-206CC...53da477711
as u can see them ,, are they good quality ? and will they fit my 206 phase 2 ? as u know i have crystals headlight are they plug and play like what they say ?
ReeVo
PostPosted: Wed Aug 25, 2010 4:56 pm Up
Hell, crazy money!
You can get them for £60-£70 second hand. I am guessing your location goes against you there though.
Answering your question, they look very good, shouldn't be a problem for quality and will fit straight on.
Team: Slightly addicted to 206Info.co.uk Wink
Team: PS CS4 Razz
saiefovech
PostPosted: Wed Aug 25, 2010 5:00 pm Up
ok guys any one can tell me what is this ???? where i have to connect this in red ??
does i have this connector in the car original headlight ?? iam so confused
PostPosted: Wed Aug 25, 2010 11:42 pm Up
TO THE H7 PLUG FROM YOUR CAR LOOM
saiefovech
PostPosted: Thu Aug 26, 2010 1:13 am Up
i ve contacted the seller and he told me the main beam lamp is h3 !! and the high beam lamp id h1 !! but i usualy know that the main beam lamp is h7 so is there any diffrence ?
saiefovech
PostPosted: Thu Aug 26, 2010 7:03 am Up
please can any one answer ? because i wanna buy them ,, so if there's any problem with h3 ill buy em
Golfguy206
PostPosted: Thu Aug 26, 2010 7:26 am Up
The bulbs are different to your standard ones but that wont make any diff to fitting them to your car.
You have a 3 pin connector (if you have crystal lamps as standard - 2 H7 bulbs for dipped and main beam). Whe you fit these, you disconnect the 3 pin plug that connects to your normal headlights and plug this into the new plug on your new lights, and bamo! job done!
Original Info member since June 2006.
2002 (plexed) China Blue 206 1.6 XSi - but it needs Coilovers!!
saiefovech
PostPosted: Thu Aug 26, 2010 9:18 am Up
thaaaaaaaaaaaaaaaanks for help Smile i appreciate it
