Posted: Wed Aug 25, 2010 4:52 pm |
heelo guys ,, found this angels in ebay
cgi.ebay.com/206-206CC...53da477711
as u can see them ,, are they good quality ? and will they fit my 206 phase 2 ? as u know i have crystals headlight are they plug and play like what they say ?
Posted: Wed Aug 25, 2010 4:56 pm |
Hell, crazy money!
You can get them for £60-£70 second hand. I am guessing your location goes against you there though.
Answering your question, they look very good, shouldn't be a problem for quality and will fit straight on.
| Team: Slightly addicted to 206Info.co.uk
Team: PS CS4  | |
Posted: Wed Aug 25, 2010 5:00 pm |
ok guys any one can tell me what is this ???? where i have to connect this in red ??
does i have this connector in the car original headlight ?? iam so confused
Posted: Wed Aug 25, 2010 11:42 pm |
TO THE H7 PLUG FROM YOUR CAR LOOM
Posted: Thu Aug 26, 2010 1:13 am |
i ve contacted the seller and he told me the main beam lamp is h3 !! and the high beam lamp id h1 !! but i usualy know that the main beam lamp is h7 so is there any diffrence ?
Posted: Thu Aug 26, 2010 7:03 am |
please can any one answer ? because i wanna buy them ,, so if there's any problem with h3 ill buy em
Posted: Thu Aug 26, 2010 7:26 am |
The bulbs are different to your standard ones but that wont make any diff to fitting them to your car.
You have a 3 pin connector (if you have crystal lamps as standard - 2 H7 bulbs for dipped and main beam). Whe you fit these, you disconnect the 3 pin plug that connects to your normal headlights and plug this into the new plug on your new lights, and bamo! job done!
Posted: Thu Aug 26, 2010 9:18 am |
thaaaaaaaaaaaaaaaanks for help i appreciate it
