Latest: tbafonso
Overall: 17130
Online Now [140]:
Visitors: 139
Today: 63333
Total: 102907130
Forums › The Car › 206 Talk › Part number request: White clip inside of the door
Mike
PostPosted: Fri Sep 24, 2010 10:24 am Up
Trade Rating: +28
This is the clip which holds the 'arm' from the central locking solenoid to the back of the door handle to allow the handle to be raised. As you can see mine has snapped so after the part number for a new one. (Ignore the blue paint.)
Cheers.
PostPosted: Fri Sep 24, 2010 10:49 am Up
Why not just go to the dealer and show them what you want?
Mike
PostPosted: Fri Sep 24, 2010 4:57 pm Up
Trade Rating: +28
If you had seen how unhelpful my local dealer s you would know why!
Mike
PostPosted: Sat Sep 25, 2010 12:07 pm Up
Trade Rating: +28
*Bump*
MFACTOR001
PostPosted: Sat Sep 25, 2010 3:38 pm Up
There is something called service box do a serch all parts and part numbers on there
MFACTOR RAP1D HDI
TEAM: NO BASE JUST RAW ENGINE
Tools are cheap experiance is invaluable
I make no appolagies for spelling punctuation
PostPosted: Mon Sep 27, 2010 1:00 pm Up
Part Number 9147 21 @ 58p
