Latest: tbafonso
Overall: 17130
Online Now [46]:
Visitors: 45
Today: 18368
Total: 104527962
Forums › The Car › 206 Talk › 206 GTi loss of Revs...Idle Control Valve or...?
Surfer333
PostPosted: Fri Oct 08, 2010 1:00 pm Up
Hi All,
Yet again the 206 GTi is playing up.
This time on way home, From 1st turn of ignition and starting the engine, the cars revs were under 1000 and then dropped so low the car stalled, and engine stopped.
I have put it down to needing a new Idle Control Valve (ICV)? Could I be right, or perhaps its the Map sensor as well as the ICV?
So were would the ICV be located on the 206 GTI - I thought it is / should be located on the inlet manifold am I right?
Cheers,
Smile
View user's profile Visit poster's website AIM Address MSN Messenger
roberto.f
PostPosted: Fri Oct 08, 2010 5:50 pm Up
To get to the ICV, i just took out the air filter housing and the air hose. Then the throttle body cover will lift off and leave you with the throttle body exposed. Then its just two torx bit screws to take the icv out.
That's what i did anyway. Smile
Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi
PostPosted: Sat Oct 09, 2010 12:22 am Up
If thecar will still run on the throttle then chances are it is the idele control valve at fault.
The idle control valve has been removed from the picture below. To get to the throttle body use a large screwdriver to undo the large jubilee clip holding the air scoop in place then pull the scoop off.
Surfer333
PostPosted: Sat Oct 09, 2010 2:24 am Up
Hi all,
Yes the 206 GTi did run okay on the throttle (meaning it was okay whilst driving, no loss of revs or power) but rev counter is deff being out of kilter and am also sure it has to be the ICV. So thank you all for the info and help.
I'll take it out today and give it a clean and just maybe that might fix it!
Otherwise its time for a new one.
Cheers,
Smile
Surfer333
PostPosted: Sat Oct 09, 2010 4:39 am Up
£99.99p for a new ICV bloody hell!
PostPosted: Sat Oct 09, 2010 7:39 am Up
I've got a perfectly clean one sat in my old TB if you want one.
Surfer333
PostPosted: Sun Oct 10, 2010 11:52 am Up
Very Happy
Yes Edward that be really kind of you. So let me know how, when and where to send addy details to you etc?
Thanks Thats Fab. Wink
ryanbfox
PostPosted: Sat Jun 11, 2011 3:33 pm Up
hi just wanted to ask a question, do you know or could you tell me why when idling my cars revs are bouncing ever so slightly, my cat has gone, could it be because of that? my rev counter is not moving just the engine ticking over doesnt sound right
Ryan
