Latest: Stu-mill
Overall: 17131
Online Now [203]:
Visitors: 202
Today: 16904
Total: 104806325
Forums › The Car › 206 Talk › GTi people. which one do i need?
Kersh
PostPosted: Wed Nov 03, 2010 11:19 am Up
went on eurocarparts and put in my reg.
searched for engine temp sensor and its brought up two results..
which one do i need??
cars a 51(2001) plate GTi 138
number one
number two
appreciated!
Member number: 36
NICKST
PostPosted: Wed Nov 03, 2010 12:51 pm Up
On the gti 180 it's 100% the second one not sure if it's the same on the gti 138.
PostPosted: Wed Nov 03, 2010 2:51 pm Up
If it's the ones that's fitted to the thermostat housing it's the green sensor. Some 206's do use two coolant temp tensors though although not on a 138 GTi.
