Latest: Beduff1977
Overall: 17134
Online Now [891]:
Visitors: 890
Today: 109351
Total: 107511008
Forums › The Car › 206 Problems › Indicators with a mind of their own!
JJ0063
PostPosted: Wed Dec 08, 2010 1:49 pm Up
Hi all,
Just a quick question about indicators here..
I started the car up this morning and the right indicator was on.. but the stalk was in the 'neutral' position i'll call it!
Now I flicked it to the left, and left came on, but then put it back to 'neutral' and the right one came on?
Is this just a case of whacking a bit of vaseline on the switch?
if i really carefully and slowly move the stalk about i can make them go off... sometimes for literally 3-4 seconds, or sometimes for a whole journey.
quite annoying when im driving down the road with people flashing their lights cause they think i dont realise my indicator is on! lol
Cheers
Jordan
tamz
PostPosted: Wed Dec 08, 2010 1:55 pm Up
mines done that aswell mate , get another stalk n it will be fine lol
JJ0063
PostPosted: Wed Dec 08, 2010 2:08 pm Up
i'll try the vaseline trick for a hopeful temporary fix as it may just be a dry connection i hope!
JJ0063
PostPosted: Wed Dec 08, 2010 2:34 pm Up
Are the peugeot indicator stalks interchangable? Ie. will one from a 106 or 306 fit? As there's no 206's at my local scrappy.
Cheers!
Thunderchild
PostPosted: Fri Dec 10, 2010 7:02 am Up
Hi, you can take the stalk apart and give the metal plates a clean, check nothings snapped or come loose. This worked for me and I've had no problems since.
Jordy
S4M106
PostPosted: Fri Dec 10, 2010 7:23 am Up
My Mrs has the same problem with her corsa ! lemme know of the outcome pleasee Smile
JJ0063
PostPosted: Fri Dec 10, 2010 2:45 pm Up
I did as Thunderchild said (Had already done it before checking back here - good thinking! Wink )
I took it apart & put it all back together again & its been fine since.. touch wood!
sniper69
PostPosted: Fri Dec 10, 2010 2:48 pm Up
i have a 206, when i indicate right and turn in to a street, my indicaters automatically start indicateing left, its so annoying... i have been told its a common thing on peugeots. good luck, update me please what you do to rectify it.... thanx.
Snipes
JJ0063
PostPosted: Fri Dec 10, 2010 2:49 pm Up
read my above post! take the stalk off.. prise the top cover off.. clean the metal contacts... could even put a blob of vaseline in the joints to stop getting a dry joint.. put back together & hope for the best! Took me no more than 15 mins from start to finish including taking the cowling etc off
