Online Now [548]:
Visitors: 547
Today: 13842
Total: 105907881
Forums › The Car › 206 Problems › Peugeot 206. Water Sloshing Noise coming from engine bay?
James28
PostPosted: Sun Dec 12, 2010 12:11 pm Up
Hi
I have a 2002 Peugeot 206 (1.4 8v) that has done 70 000 miles.
I've only recently got it last week, from a second hand car dealer.
However when driving I've noticed I'm getting a really loud sloshing noise, coming from the engine bay, as if water is rocking from side to side or something. There's no particular pattern to it, but I think it is slightly linked with when I go round corners. It really sounds like a lot of water :S
I think its started ever since I squirted the windscreen washer stuff?
Does anyone know what it could be, or how to solve the problem.
Thanks!
robdob
PostPosted: Sun Dec 12, 2010 1:47 pm Up
i had something similar to this and it was where it was overheating. the water was boiling and that caused a sloshing sound. not sure if this is the same sort of problem but ive been tryin to sort mine for like 2 months and still no resoultion yet :/
James28
PostPosted: Sun Dec 12, 2010 2:29 pm Up
Oh right, yea that could make sense, because a warning light comes on the dash and there's a loud beeping, when its used on longer journeys and the engine warms up.
It looks like an oil can light. Did think that might be a seperate problem as it looks like an oil light however?
When you say the water, do you mean the coolant/antifreeze?
James
PostPosted: Sun Dec 12, 2010 2:44 pm Up
Check your coolant levels! My old cavalier did this, my gasket went and was causing water to leak.
James28
PostPosted: Sun Dec 12, 2010 3:07 pm Up
When she got the car, I checked it over, and found that the coolant had all frothed up, and was like a cappucino, in substance and colour! She had that changed under warrenty, but the sloshing is still there?
Its like a rocking, from side to side, but loudest when in the passenger seat.
Edit: the light that flashes on longer journeys is the oil pressure/temperature light? Any links to that?
James
pugster206
PostPosted: Sun Dec 12, 2010 4:37 pm Up
i had this sort of problem when i bought the car soon i start it up sounded like a gush of water moving towards the passenger side and it was drinking coolant, dunno if its same problem but i just bought a new radiator and bottom hose for the radiator. have you seen any leaks or spills around the car?
James28
PostPosted: Mon Dec 13, 2010 6:05 am Up
Pugster thats exactly what it sounds like I think.
Ahh right, Im fairly certain it must be to do with coolant now.
Its not actually my car, so I'll check the levels when I have another look.
Would this also be linked to the problem of that warning light coming on?
James
PostPosted: Mon Dec 13, 2010 6:07 am Up
You need to bleed the engine coolent through, you have an airlock
James28
PostPosted: Mon Dec 13, 2010 8:28 am Up
How do I go about doing that, I've done it on a Clio but not on a 206?
Does anyone know Where are the bleed screws on a 2002 206 1.4 8v are?
James
PostPosted: Mon Dec 13, 2010 9:48 am Up
Check the oil level with the dipstick under the bonnet & make sure its got the correct grade of oil in.
Make sure its got a genuine Peugeot / Citroen OR Purflux oil filter fitted.
Change the oil pressure sender.
pugster206
PostPosted: Mon Dec 13, 2010 11:08 am Up
if it is same problem, check coolant level before you go out and when you come back check the hoses for leak. Thats how i spotted the problem after i heard gushing of water. When pressure was applied the coolant was just drinking up and not returning back to the reservoir. I then noticed water underneath the the car coming from the radiator with the bottom hose leaking. just check any spillages around the car when parking up after pressure has been applied to send the coolant flowing
hope thats helps a little
pugster
sutherton1990
PostPosted: Fri Dec 17, 2010 3:58 am Up
its the radiator in your heater matrix check passenger side footwell under the floor mat if there water there its definetly that bout 60 quid
panason1c
PostPosted: Fri Dec 17, 2010 4:14 am Up
The scuttle drain tubes are blocked, probably by leaves, causing a build up of rain water to slosh around the scuttle (the area below the windscreen wipers, under the bonnet)
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
luvpug
PostPosted: Sun Jan 02, 2011 1:13 pm Up
Ive got the same problem - check my forum.
First and obvious thing is your Heater Matrix! You may have air in the coolant which could cause head gasket failure (did on mine) so get it checked for air asap. Just needs bleeding but dont ignore it.
Luvpug
mjsroofing
PostPosted: Sun Jan 02, 2011 1:20 pm Up
i'd go for this one to start.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
