Latest: S2cgm
Overall: 17178
Online Now [873]:
Visitors: 872
Today: 54916
Total: 137121897
Forums › The Car › 206 Problems › loss of power and stalling!
RossH
PostPosted: Tue Dec 28, 2010 11:37 am Up
just been out for some food and when we got back in the car the revs dropped to under 1000 n the car was juddering with no power at all, turned it off and on and seemed fine until tried to reverse out the space and it stalled, it did these again and again and i had to start it up about 5 times until it started to move and then about 20minutes later the revs dropped all of a sudden and started juddering again. any ideas? the car is a 2003 1.4 8v
2003 lx Aluminium Silver, 16' Nimrods, ph2 Bootstrip, ph2 Rear Lights, K&N Panel Filter, Alpine ida-x200 HU, Alpine Type E Door Speakers, Vibe Sub, Part GTi Interior
PostPosted: Tue Dec 28, 2010 11:41 am Up
Try cleaning the idle control valve for starters.
PostPosted: Tue Dec 28, 2010 11:46 am Up
2nd one of these today Laughing
See this post for help Wink
www.206info.co.uk/Foru...tml#264962
RossH
PostPosted: Tue Dec 28, 2010 11:50 am Up
may sound stupid but how do i do that or is it best to send it to a garage?
PostPosted: Tue Dec 28, 2010 11:51 am Up
Give what MRBSI says a check and also check out your coil pack and spark plugs
PostPosted: Tue Dec 28, 2010 11:52 am Up
Its pretty easy DIY.
You need to remove 2 x torx 20 screws to get the stepper motor out / back in again, don't loose the O ring seal of the end.
WD40, some paper towel's & some cotton buds are all really you need to clean it with.
RossH
PostPosted: Tue Dec 28, 2010 11:54 am Up
Razpulsedj wrote:
Does your car judder at all?
yes it does judder and no power but if i restart it it doesnt, but it doesnt like moving and just stalls very very easy.
PostPosted: Tue Dec 28, 2010 11:57 am Up
Heres a guide i made how i sorted my juddering mate
206 Juddering Solved
Hope this helps
Also if your in need of a coil pack i have 1 for sale
PostPosted: Tue Dec 28, 2010 12:12 pm Up
If the car will run normally when the throttle is applied it's probably not the idle control valve.
