Latest: tebas93089
Overall: 17179
Online Now [45]:
Visitors: 44
Today: 34632
Total: 138181515
Forums › The Car › 206 Talk › Indicator stalk
Indicator stalk
maximus.darby
PostPosted: Tue Jan 04, 2011 7:51 am Up
Hi All,
I have a problem with my fog light switch, where even if the swtich is set to off, and the ignition is off, the front fog lights stay on, and I need to manually remove the fuses.
I'm wondering if anybody has any idea how much it would be to get a new stalk from Pug, and get it fitted?
Max Darby
Peugeot 206 Quiksilver, 1.4, 51 Reg, 34,000 Miles
PostPosted: Tue Jan 04, 2011 8:21 am Up
Will be a new stalk if your non-plexed or a new Com2000 if your plexed.
Fit them yourself its easy.
£232 for a new Com2000
£54 if its a stalk
maximus.darby
PostPosted: Tue Jan 04, 2011 10:29 am Up
yeah i believe it's non plexed. Is it just a case of un screwing and clipping back on the new one?
Max Darby
PostPosted: Tue Jan 04, 2011 10:40 am Up
Yeah takes 5 mins, you have to remove the shroud to reveal it, a couple of torx screws:)
PostPosted: Wed Jan 05, 2011 5:09 am Up
Id unplug the stalk first & see if the front fog lights then go off.
That will tell you if its:
The stalk
OR
The front foglight relay
Its sounds more like the relay to me Wink
maximus.darby
PostPosted: Wed Jan 05, 2011 10:27 am Up
is the relay an expensive problem.....pulling out the front fuses has been the cheapest option for me right now Smile
Max Darby
dmxking512
PostPosted: Wed Jan 05, 2011 10:52 am Up
Relays will be a hell of a lot cheaper than a stalk or a Com2000
