Latest: Beduff1977
Overall: 17134
Online Now [342]:
Visitors: 341
Today: 79053
Total: 106939560
Forums › The Car › 206 Problems › Car still stalling after suggestions
RossH
PostPosted: Mon Jan 10, 2011 11:51 am Up
About a week ago i posted about my 1.4 8v juddering and stalling on start up and people suggested cleaning my stepper motor so iv cleaned that and it was quite dirty and iv changed my coil pack aswel, but stil no change, just wondering if anyone has any other ideas?
Thanks, Ross
2003 lx Aluminium Silver, 16' Nimrods, ph2 Bootstrip, ph2 Rear Lights, K&N Panel Filter, Alpine ida-x200 HU, Alpine Type E Door Speakers, Vibe Sub, Part GTi Interior
Mattie-RS
PostPosted: Mon Jan 10, 2011 11:59 am Up
Next step id take is renewing the sparks
I'd have done that before changing the coil pack, its cheaper Laughing
RossH
PostPosted: Mon Jan 10, 2011 12:08 pm Up
cheers for that, what are the best spark plugs bosch or NGK?
Mattie-RS
PostPosted: Mon Jan 10, 2011 12:12 pm Up
Bosch
Coilpacks dont react well to NGK sometimes on 206's
Danny.
PostPosted: Mon Jan 10, 2011 1:28 pm Up
Clean the Idle Control Valve
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Andy180+
PostPosted: Mon Jan 10, 2011 1:38 pm Up
they are well known for number one injector going down too. does the engine management light come on at all when it judders???
Ash
PostPosted: Mon Jan 10, 2011 1:41 pm Up
He said he cleaned the Stepper Motor (same thing)...
PostPosted: Mon Jan 10, 2011 1:46 pm Up
Could be any of the sensors...map sensor, lambda sensor, throttle position sensor...list is endless.
gti180boy
PostPosted: Mon Jan 10, 2011 3:00 pm Up
Edward is wright really.
When you say its juddering do you mean its missfiring???
Can you give more info whats it is doing?? because all mechanics will say its hard to say whats the fault is intill you see it in person faulting??
why dont you get the car scaned by garage???
180 Doctor
