Posted: Sat Jan 15, 2011 5:30 am |
I have replaced the engine cover mounting studs/clips so many times that i looked for an alternative. I found a far better product on e-bay link below. They look far stronger and better designed and hopefully will last longer.
cgi.ebay.co.uk/peugeot...25606ce43e
If that link works i hope it helps other members.
Posted: Sat Jan 15, 2011 7:47 am |
When you say you have replaced them many times, which ones did you fit?
The w**ky original type bought cheap from Ebay?
The much better modified ones sold by Peugeot / Citroen main dealer's?
Posted: Sat Jan 15, 2011 9:15 am |
Both. First were Peugeot which broke within a year then tried cheapo e-bay ones which lasted almost the same length of time. None of which were a satisfactory solution hence looked for a better design which these appear to be. Time will tell though but as i said they do look far stronger.
Posted: Sat Jan 15, 2011 9:25 am |
Not heard of any cases of the new Peugeot / Citroen type cover clips breaking
Posted: Sat Jan 15, 2011 9:26 am |
They'll be fine. Look pretty s**te tho with them been wing nuts.
