Latest: S2cgm
Overall: 17178
Online Now [153]:
Visitors: 153
Today: 131340
Total: 137661510
Forums › The Car › 206 Problems › loss of power/juddering
gaffy
PostPosted: Sun Jan 16, 2011 12:18 pm Up
hi guys, me an the misses set off in the car to do a bit of shopping today, car started an drove like normal, however after returning back to the car started fine, but when i pulled off she was very juddery an very little power when eccelerating, so i decided to take the car back home which was a struggle, as i could go no faster than 25 mph. i have done a search on the problem which makes me think it could be the coil pack. can anybody shed any light on my problem as the misses needs the car for work. oh an the car is w reg gti many thanks
chin up lad
PostPosted: Sun Jan 16, 2011 1:13 pm Up
Deffo coil pack or spark plugs mate, look under the bonnet while the engine is running and see if there is any jolts of electricity coming from the coil pack and going to the rocker cover, if so then you need a new coil pack which you can get from a scrappy from a 206 and a saxo. Also like i said check your spark plugs to see if its them
PostPosted: Sun Jan 16, 2011 1:16 pm Up
What He Said
gaffy
PostPosted: Sun Jan 16, 2011 1:27 pm Up
ahh thanks v much for replys, i shall pick one up tomorrow, are they easy to change?
chin up lad
dopey
PostPosted: Sun Jan 16, 2011 1:42 pm Up
I had that with mine when i was up in newcastle 360 miles away from home and needed to travel to manchester same day so had to pay out £200 at dealership. killer.
gaffy
PostPosted: Sun Jan 16, 2011 1:45 pm Up
chin up lad
gaffy
chin up lad
giveitsomebar
PostPosted: Sun Jan 16, 2011 2:30 pm Up
yeah fairly simple
jamiea69
PostPosted: Sun Jan 16, 2011 3:34 pm Up
check the brand of your coilpack, there was a alot of problems with the sagem coilpacks, i had same problem and i changed it for different brand and it was sorted
225 cupra r
