Latest: tbafonso
Overall: 17130
Online Now [409]:
Visitors: 408
Today: 159990
Total: 102735880
Forums › The Car › 206 Talk › 206 Gti Hdi
206 Gti Hdi
sir_dave
PostPosted: Fri Jan 21, 2011 11:02 am Up
Hi there,
probably my 1st post since the server crashed & wiped everything, so bear with me ...
Used to have a 2.0 hdi xsi, that did me proud for 3 years & 100k, but it developed a misfire at 1800rpm and cost me a HP & LP fuel pump, 4 x injectors & a clutch towards the end of its life, which kinda put me off dervs!!
However, im currently doing 600 miles a week (minimum) in my 330i and the cost is starting to get a bit daft at 29mpg.
As such, im looking at another 206, purely as they are cheaper than the usual VAG stuff. And they drive nicer Smile
So, tell me all you know about the Gti Hdi please, i hear about issues with FAP & Dual mass flywheels/clutches/turbos.
Info & costs to replace when they break please.
Ta
330ci Sport for Show
182 Trophy for Go
paulrushton
PostPosted: Fri Jan 21, 2011 11:11 am Up
Not had my hdi gti long (2 weeks). It averaged 44mpg on first tank of mainly slow traffic and a bit of motorway. (the car showed 53mpg so way off the actual).
I bought a lemon and had to put new brakes all round (discs and pads). It had a broken coil spring and various other niggles. I currently have an UNBLOCK DIESEL FILTER warning but having had the fault code read it relates to a fuel cap sensor (£63 from Pug).
Coming from a large estate it's definitely different and the rides a bit firmer. Overall though I'm liking it and don't mind getting my hands dirty to sort the little niggles out.
Peugeot 206 GTI HDI Black
PostPosted: Fri Jan 21, 2011 11:13 am Up
I am sure the dual mass flywheel (or something similar) is a complete ballache if it goes. Also the FAP can be a complete d*ck as well.
Otherwise its quite a good car. Got lots of little goodies and is 110bhp as standard. Smile
sir_dave
PostPosted: Fri Jan 21, 2011 11:29 am Up
My 330i has 231bhp and my Clio Trophy 175, so im not likely to get too excited about 110bhp Wink 55mpg is more interesting though!!
What sort of cost are we talking about to replace a DMF/clutch?
RS Tuning quoted me £400 to remap/remove the DPF and i can just get a straight pipe to remove the actual filter easy enough, but a clutch change isnt something i fancy doing on the drive tbh, so id have to factor that into running costs, ie pay someone to do it ...
182 Trophy for Go
PostPosted: Fri Jan 21, 2011 11:32 am Up
As standard. Wink Implying, add a bigger FMIC and re-map. Wink This = decent torque figures whilst retaining most of the fuel economy. Wink
PostPosted: Fri Jan 21, 2011 11:35 am Up
It's booked at a 10hour job to change it, because the engine has to come out.
I'd avoid the 1.6HDi tbh.
sir_dave
I like this idea.
Although 90 miles a day commute down the M3 requires mpg's 1st & foremost. And reliability!! Which is the bit im slightly concerned about at the moment.
10 hrs!!! Bloody hell, is that for DMF & Clutch? What sort of cost we looking at for that Confused
182 Trophy for Go
PostPosted: Fri Jan 21, 2011 11:40 am Up
sir_dave wrote:
I like this idea.
Most garages charge around £50. Peugeot Carlisle charge £86 an hour.
So around 500-860. Wink
kieron
main stealer around £800
Account suspended
Ruffy_206
PostPosted: Fri Jan 21, 2011 11:46 am Up
Custom - Gold Stars
so say clutch can be converted to singla mass. will feel a bit lumpy but sould be alot better for wear and lasting. and if your thinking of a map then it will kill the dual in no time.
low milage stuff is ok but when stuff needs replacing then i think it gets pretty dear not unless you look at one with it all done.
sir_dave
PostPosted: Fri Jan 21, 2011 11:57 am Up
So £800 for a clutch, & £500 for a remap/DPF removal.
Both are likely to go.
£1300 buys a hell of a lot of petrol for my 330!!
FLOL. 206 not looking so great.
182 Trophy for Go
PostPosted: Fri Jan 21, 2011 11:59 am Up
Get a 2.0hdi. Wink
sir_dave
PostPosted: Fri Jan 21, 2011 12:15 pm Up
tomd0801754 wrote:
Get a 2.0hdi. Wink
Nah, the memories of pouring money down the toilet towards the end are just too much to bear lol ...
RY53 DCV. Avoid it Laughing
182 Trophy for Go
