Posted: Fri Jan 14, 2011 3:34 pm |
well a engine conversion is going to be alot more than cams and a remap lol
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Fri Jan 14, 2011 3:35 pm |
true but id rather do tht lol it will be more fun lol
Posted: Fri Jan 14, 2011 4:07 pm |
i am confused now.
are you going to do the conversion yourself or are you paying people to do that for you?
Posted: Sat Jan 15, 2011 2:29 pm |
depends how much the companies charge
Posted: Sun Jan 23, 2011 1:47 pm |
Don't think such a project would be worth it, through all the problems of changing the actual engine, buying everything, to possible trouble popping up after the engine conversion is done... Easier saving up for another 6 months and buy a new car immediately...
Posted: Sun Jan 23, 2011 2:28 pm |
but the point is i don't want another car :/ see this kinda annoys me bout this is most people who waana do stuff like this usually get gunned down buy people sayin nooo its not werth it nd stuff but if people want to do it then give them encouragement bout it , most things are pointless but if people have the heart to do it give them a lil bit of hope
Posted: Sun Jan 23, 2011 2:31 pm |
Dont bother dude, tune the engine youve got. its probably the most commonly tuned peugeot/citroen engine or a hybrid of it so parts are easy to get hold of, knowledge is known and you could see around 300bhp from forged internal and turbo etc alot of power for such a small car.
| 206 1.6 16v, Nimrods, Full SP Kit, 3 Stage Valve Cut Head, 4-1 Manifold With Decat, Pug Sport Backbox, Vibe Speakers, HIDs In Projectors, DVD screens & Sub  | |
Posted: Sun Jan 23, 2011 2:32 pm |
true... My point is that i was also interested in doing such a conversion, and the costs and time was was proposed was totally overwhelming... But it depends on your case and your car...
Posted: Sun Jan 23, 2011 2:34 pm |
turbos cost to much money tho id rather take mine off the road nd put a gti lump isn't it or something like tht . but i was thinkin bout puttin lightweight flywheel, cam , remap , maifold , injectors, walbro uprated fuel pump on my 1.6 , with a upgraded coolin fan and a alloy radiator
Posted: Sun Jan 23, 2011 2:35 pm |
but i know people are gonna be like wats the point its a 1.6 :/
Posted: Sun Jan 23, 2011 2:44 pm |
Dude, I personally thing the 1.6 is a better engine than the 2.0 gti and gti 180. You look at 106 gti's and saxo vts. People get some power out of those!
Posted: Sun Jan 23, 2011 2:47 pm |
XSIcheeseman wrote: |
but i was thinkin bout puttin lightweight flywheel, cam , remap , maifold , injectors, walbro uprated fuel pump on my 1.6 , with a upgraded coolin fan and a alloy radiator |
Why do you need an uprated fuel pump and cooling fan?
Posted: Sun Jan 23, 2011 3:04 pm |
Lewis1304 wrote: |
Dude, I personally thing the 1.6 is a better engine than the 2.0 gti and gti 180. You look at 106 gti's and saxo vts. People get some power out of those! |
you can't compare a 2.0 to 1.6, considering the torque and power power 2.0 still has an advantage. but that doesn't mean the 1.6 is a bad engine.
i would tune the 1.6 or 2.0 lump. but i wouldn't drop a 2.0 lump and then tune it. it is just asking for troubles and $ as well. not to mention gti nowadays are as cheap as chips
i think ill e-mail ecosse . does anyone know if you have to supply the engine and gearbox nd stuff? |
Ecosse fit body kits and spoilers
Posted: Sun Jan 23, 2011 3:11 pm |
macj wrote: |
Ecosse fit body kits and spoilers  |
thy also do engine conversions for 3 grand
cause i just think if your gonna up power you should up the coolin system too there no point havin loadsa power nd it gettin redhot well quick all the time
