Posted: Mon Jan 17, 2011 12:51 pm |
I have searched for this info but can't find it, nor can I find it on google.
I know that Peugeot can make up a key with the key code card, photo ID and the V5C, but my question is can they ERASE just one single key (without the key being present) from the car so that it's not able to remotely unlock / start the engine?
Posted: Mon Jan 17, 2011 12:53 pm |
no , but what they can do is reprgame the keys that you do have, that way the old key wont work because it hasnt been reprogramed. unfortunatly they could still be able to get in the car.
| 2.0 hdi 90
challenger alloys
-40mm spax shocks and springs
gti 180 calipers, groved discs
braided brake lines
turbo back pro-speed exhaust
de-egr'd | |
Posted: Mon Jan 17, 2011 4:27 pm |
Cheers. Might ring them tomorrow to see what they can do.
Posted: Mon Jan 17, 2011 4:29 pm |
troy wrote: |
no , but what they can do is reprgame the keys that you do have, that way the old key wont work because it hasnt been reprogramed. unfortunatly they could still be able to get in the car. |
Won't you have to virginise the ECU to do that tho?
Not sure if you program it thru Peugeot Plant. If I remember, I'll have a look for you tomorrow Gareth
Posted: Mon Jan 17, 2011 4:32 pm |
Thanks Lee
Posted: Mon Jan 17, 2011 5:03 pm |
On a multiplexed 206 like this everytime you code a key you start from scratch with 0 keys in the BSI system as it erases them all.
Take ALL the key's you want to work with the car & get them recoded, any that aint recoded at that time will no longer work the remote locking or the transponder immobiliser.
Posted: Mon Jan 17, 2011 5:08 pm |
Right. So if i've got this right, If i take the 1 key that I have and the car to Peugeot to get another one made up, when they program up the new key all the keys that are currently registered with the BSI will be forgotten and the one i buy from the dealer and the one i have now will be the only keys that work?
besides the barrel locks obviously.
Thanks for the input!
Posted: Mon Jan 17, 2011 5:09 pm |
pug206lx wrote: |
Correct.
Posted: Mon Jan 17, 2011 5:10 pm |
That's brilliant. Thanks!
Posted: Wed Jan 26, 2011 3:30 pm |
I know this was a while ago now but does anyone know the difference between the remote boards with numbers 73373067C and 73373067B by any chance?
Posted: Wed Jan 26, 2011 3:36 pm |
pug206lx wrote: |
That's brilliant. Thanks!  |
let us know what they charge for this
Posted: Wed Jan 26, 2011 3:37 pm |
Ones 'improved range' and the other one is standard. Can't remember which one is which, but I'd hazard a guess the C one is improved range.
Posted: Wed Jan 26, 2011 3:52 pm |
Cheers Lee. Bought a key off the Bay of E and thats the only difference on the remote board, even if that doesn't work i can live without remote on the spare. So ill get a blade cut and take it to pug and see if and what can be reprogrammed. Got to be cheaper than buying a whole key even if i do end up having to bite the bullet and have a new transponder chip.
And will do stevedude.
Posted: Wed Jan 26, 2011 3:56 pm |
Posted: Wed Jan 26, 2011 4:05 pm |
Thats fab Lee, Cheers. If i ever meet you ill buy you a pint for your help
