Latest: Beduff1977
Overall: 17134
Online Now [484]:
Visitors: 483
Today: 61235
Total: 107051217
Forums › The Car › 206 Talk › Shiny exhaust?
Shiny exhaust?
Mike_XS
PostPosted: Fri Jan 28, 2011 5:24 pm Up
I've just taken my 3" sportex off (bringing the car to the mainland in a couple of weeks and want the best MPG on the motorway as I can get...) and the once shiny end bit is now dull and crappy.
Just wondering if anyone had any tips on the best way to keep it looking nice and shiny?
Cheers, Mike
lofty
PostPosted: Fri Jan 28, 2011 6:14 pm Up
Give it a wipe down and use Autosol metal polish on it (about 3 quid from halfords and lasts for years).
It should be ok on stainless exhausts but double check first.
206 GTI
Nimrods
SP Grille
Cargo Net!
Leader Team: Tivoli GTI
Leader Team: Cargo Net
Snowboard & Bindings For Sale
PostPosted: Sat Jan 29, 2011 2:03 am Up
Autosol is perfect for stainless. A backbox will make no difference to mpg.
Danw_VVT
PostPosted: Sat Jan 29, 2011 3:26 am Up
also give it a polish before using the autosol with 4000 grit paper. I use abraclean which is perfect.
bertt
PostPosted: Sat Jan 29, 2011 4:22 am Up
fine wire wool will do it fine, mine came up like new.
bashyy1
PostPosted: Sat Jan 29, 2011 4:56 am Up
how? My car drinks a HELL of alot of more petrol now then when i had a standard one on
Aegean Blue Gti 180.
Project Thread
PostPosted: Sat Jan 29, 2011 4:57 am Up
You were probably driving it harder when having an exhaust to listen to.
vintageoriginal
PostPosted: Sat Jan 29, 2011 5:29 am Up
This is true. Wouldn't bother taking it off, just ease off that right pedal a bit Very Happy
Quiksilver: 1.6 16v Engine Conversion.
Mike_XS
PostPosted: Sat Jan 29, 2011 8:59 am Up
A sports back box will affect the fuel economy of a car.
Cheers guys, I'll give it a go Smile
