Posted: Mon Jan 31, 2011 6:32 am |
Are available for €2550+Tax...which I don't think is too bad considering what you'd pay to build one as parts. Last time I looked a UK dealer would want about double that price...
www.peugeotsport-racin...05_01.aspx
Posted: Mon Jan 31, 2011 6:34 am |
Thinking of a conversion?
Posted: Mon Jan 31, 2011 6:35 am |
... for the Jetta?
Whats the spec on them..? or are they completely standard engines..? IIRC the GTi180 engine is a small fortune standard direct from Peugeot.
Posted: Mon Jan 31, 2011 6:36 am |
A brand new GTI 180 engine from Peugeot is £6224.10 including VAT
That Peugeot sport engine is a bargain at that price
Posted: Mon Jan 31, 2011 6:57 am |
Uz wrote: |
Whats the spec on them..? or are they completely standard engines..? IIRC the GTi180 engine is a small fortune standard direct from Peugeot. |
It says standard engine on the site.
Posted: Mon Jan 31, 2011 7:15 am |
Comes with both manifolds, Tb...everything except alternator and A/C pump.
Posted: Mon Jan 31, 2011 7:17 am |
For the same price you can buy a secondhand engine - complete with car
Posted: Mon Jan 31, 2011 7:34 am |
but that is just a standard engine i would have though.....?
Posted: Mon Jan 31, 2011 8:17 am |
hi ive been on 206 info a while but i havent wrote very many posts yet i was just wondering wat these engines come with are they standard and if not wat do you get with them and wat bhp are the pushing?
Posted: Wed Feb 02, 2011 9:56 am |
It tells you on the site! Its a standard engine.
