Latest: S2cgm
Overall: 17178
Online Now [78]:
Visitors: 78
Today: 8706
Total: 137075930
Forums › The Car › 206 Problems › Spring Lengths
Spring Lengths
Spanerman
PostPosted: Tue Feb 01, 2011 12:35 pm Up
I have just taken my standard springs off my car to put onto my Gmax shocks, and one spring is about 4 inches longer than the other Confused
Is this normal or has someone fitted the wrong spring in the past?
Sam.
Hello
PostPosted: Tue Feb 01, 2011 12:36 pm Up
No springs should be the same, that's very odd...
Spanerman
PostPosted: Tue Feb 01, 2011 12:38 pm Up
Bummer, I thought that one may be shorter to compensate for the gear box being lighter than the engine.
Sam.
Hello
PostPosted: Tue Feb 01, 2011 12:43 pm Up
None of the sets I have had are different so that's what I'm going by and 4 inches is a lot as well but I see your logic
Spanerman
PostPosted: Tue Feb 01, 2011 12:44 pm Up
Yeah, looks like ill be looking out for some new springs Sad
Anyone else ever had this?
Sam.
Hello
Ste
PostPosted: Tue Feb 01, 2011 12:54 pm Up
Staff - Ste
Nope, both of my standard springs are exactly the same size.. Sounds a strange one this Confused lol
The Cars:
Uz
PostPosted: Tue Feb 01, 2011 1:03 pm Up
Cut springs can be the only possiblity I can think of tbh.
Whats the drop..? As don't forget some are progressively wound and some aren't so it depends on how they're wound aswell.
Spanerman
PostPosted: Tue Feb 01, 2011 1:07 pm Up
These are the standard springs, the car is currently -60mm and im raising it back up
Hello
PostPosted: Tue Feb 01, 2011 1:18 pm Up
Even if they were progressive uz, surely both springs would be the same?
And standard springs are definately suppose to be equal so something isn't right.
Uz
PostPosted: Tue Feb 01, 2011 1:22 pm Up
Something must have gone wrong with one of the springs...but I've just re-read the opening post and both sides should be identical lengths :S
Have you ever owned any other standard springs cause I now different 206s have different length springs but none of them are progressively coiled.
Spanerman
PostPosted: Tue Feb 01, 2011 1:25 pm Up
Nope, this is my first pug and the springs came on the car.
I replaced the entire strut with gmax -60mm kit ut now i want to put the standard springs on the gmax damper to raise the front back up.
Sam.
Hello
PostPosted: Tue Feb 01, 2011 1:29 pm Up
They are either damaged, or different springs altogether. Was it not obvious when they were fitted? But to get to the original point, you will definately need new springs Wink
Spanerman
PostPosted: Tue Feb 01, 2011 2:03 pm Up
No, the standard springs I just took off the original strut are the wrong length.
I'll have to but two standard spring
Sam.
Hello
