Posted: Thu Aug 05, 2010 10:06 am |
A does pipe type in google diesel does pipe
I want 1 soo much
Basicly you just put a straight pipe on the turbo where the air filter should go
| | ![](images/spacer.gif) |
Posted: Thu Aug 05, 2010 11:25 am |
Mine has one as it was on it when I got the car, I don't like it but I can't be bothered with removing it. ![Laughing Laughing](images/smiles/icon_lol.gif)
I always just thought they were used to reduce turbo lag, never heard anything about reducing performance.
Posted: Thu Aug 05, 2010 3:26 pm |
ive got one on my 306 dturbo they sound wicked with 26psi boost, in a daily drive you wont notice much diffrance in power, but it does feel alittle better with the dump valve blanked off!
Posted: Fri Aug 06, 2010 2:13 am |
Dump valves are very 1995...a bit naff these days.
Posted: Fri Aug 06, 2010 2:26 am |
Dump valaves usually used by Petroal Turbo engines,not diesel :),because the waste that is out more,and it need to be out,so the Turbo lag be reduced,the Turbo kicks in faster,and the turbo blades stay in good condition.
Posted: Tue Feb 01, 2011 11:29 am |
Posted: Tue Feb 01, 2011 12:24 pm |
Mine has one from derv doctor, disconnected it cause I just didn't like it don't like them on any cars, and to be fair, it sounded like one should.
It's still in there but not connected though, willing to sell it if you want it.
Posted: Tue Feb 01, 2011 1:10 pm |
| Image removed due to size
Team, ST
Team, Gti 138 track slag | |
Posted: Tue Feb 01, 2011 1:28 pm |
You can get kits that make that sound. It's like a little speaker that fits under the bonnet, sounds awesome.
Posted: Tue Feb 01, 2011 1:29 pm |
Posted: Tue Feb 01, 2011 7:39 pm |
Fake dump each to there own they can cost as much as the real thing abd that an expensive mp3player an speaker lol
Posted: Wed Feb 02, 2011 3:12 am |
why would anyone buy that? urgh idiots lol
Any work you undertake as a result of my posts is done so at your own risk ![Smile Smile](images/smiles/icon_smile.gif) | |
Posted: Wed Feb 02, 2011 3:31 am |
ooooh. dump valve
<checks wallet>
Posted: Wed Feb 02, 2011 3:44 am |
