Latest: Puggingalong
Overall: 17129
Online Now [227]:
Visitors: 226
Today: 4032
Total: 101297019
Forums › The Car › 206 Talk › Rolling Road Day Mapping 2.0 HDi
MFACTOR001
PostPosted: Wed Feb 09, 2011 5:16 am Up
|SGP| wrote:
I stopped reading when I realised you've used one full stop in your first paragraph
Then I noticed "I make no appolagies for spelling punctuation" in your sig, so.. I'm not going to bother. Sad
Atleast learn basic communication skills!
dyslexia look it up
MFACTOR RAP1D HDI
TEAM: NO BASE JUST RAW ENGINE
Tools are cheap experiance is invaluable
MFACTOR001
PostPosted: Wed Feb 09, 2011 5:54 am Up
Update
I have given the mappers chance to sort it they have altered mapp again however it is still not as good as when i took it for the alteration.
Yes it is fast drives like petrol but the torque is not there at all realy.
Now has just over 1 bar when i took it it had 1.2 bar
The car was running loveley before and without fault,with plenty of power which required a clutch upgrade.
Thay say that the origional mapper no longer works for them and they have a new one.
They have said if i am not happy with it they will refund.
Any sugestions for mapp on rr ?
MFACTOR RAP1D HDI
Jay794
PostPosted: Wed Feb 09, 2011 6:24 am Up
i didn't even know there was a reputable remapper in Sheffield. Based on this forum, I would only got to RS Tuning or Red Dot, however I have a friend that runs a place in Chesterfield that do remaps so I'd probably go there for a discount
PostPosted: Wed Feb 09, 2011 6:32 am Up
derv doctor in derby is good at diesel.
RST certainly did a great job on mapping.
or you can get mr. whibbys map (i think he is the member in the 306 forum),
or get the map from the dermark guy (can't remember his user name in here, surely he got an account in TDCO as well)
PostPosted: Wed Feb 09, 2011 6:35 am Up
btw have you got a rr for your first map?
PostPosted: Wed Feb 09, 2011 6:58 am Up
MFACTOR001 wrote:
Update
Have you changed the boost manually?
MFACTOR001
PostPosted: Wed Feb 09, 2011 4:01 pm Up
I will find rr for the first mapp i think it came in at about 125 then added stage 2 bits
I have not yet changed the boost manually i have an ajuster fitted just set to std as before it was set to std and acived upto 1.2 bar.
MFACTOR RAP1D HDI
MFACTOR001
PostPosted: Wed Feb 09, 2011 4:03 pm Up
Does anyone have contact details for mr whippy and lars ?
MFACTOR RAP1D HDI
what have you done to the car before you get the first map and rr?
PostPosted: Fri Feb 11, 2011 4:36 am Up
If the boost has changed but you haven't changed it manually then either {a} your turbo is fahooked or {b} you have a boost leak somewhere...
For Mr.Whippy go to TDOCUK. Smile
Rob2859
PostPosted: Fri Feb 11, 2011 8:58 am Up
As others have said I would give the turbo a good going over to rule out mechanical fault.
MFACTOR001
PostPosted: Sat Feb 12, 2011 8:31 pm Up
I only checked turbo just over a week ago but i will have another look some time this week
Thanks for your suggestions
MFACTOR RAP1D HDI
PostPosted: Sun Feb 27, 2011 7:27 am Up
What ahppened with this then?
MFACTOR001
PostPosted: Sun Feb 27, 2011 5:52 pm Up
My turbo died a couple of days ago and had to re do intercooler pipes so they have a lip on ends and can now clamp solid no boost leaks now still not achieving the boost I had though so it must be down to new mapp restriction .
MFACTOR RAP1D HDI
PostPosted: Mon Feb 28, 2011 6:33 am Up
did you got the bleed valve installed?
Page 2 of 3
