Latest: S2cgm
Overall: 17178
Online Now [144]:
Visitors: 144
Today: 44925
Total: 137474403
Forums › The Car › 206 Talk › locks
locks
fg-mart
PostPosted: Fri Feb 11, 2011 2:01 am Up
I don't know if this has been brought up but its a worry for me with alot of scrotes knocking about. but is their any sort of mod to strengthen the screwdriver tap trick? i know the pugs, saxo, puntos etc. are easy to get into buy tapping a screwdriver at the side of the lock. So it would be nice to strengthen it out on the inside. either that or an alarm that tells them to do one when they get to close
mart
martyn
PostPosted: Fri Feb 11, 2011 2:51 am Up
Steel plate and a box around the back of the barrel so you can't get a driver down Side of lock and if you do the box behind barrel stops you getting to the bits to unlock it.
My van has had this done to it. (not by me)
fg-mart
PostPosted: Fri Feb 11, 2011 2:54 am Up
is it a case of welding it or brackets ? and were could i get the steel plate and box
cheers
martyn
PostPosted: Fri Feb 11, 2011 3:14 am Up
Has been welded by the looks of it. I didn't do it to it so don't know were it came from.
abs06
PostPosted: Fri Feb 11, 2011 4:32 am Up
Is it true if u put a half tennis ball over the lock and push in it pops the lock. Some one at work told me able it. I want to get a alarm when i have a bit more money.
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
PostPosted: Fri Feb 11, 2011 4:35 am Up
Rolling Eyes No.
Kersh
PostPosted: Fri Feb 11, 2011 4:39 am Up
de-lock the doors completely so nobody knows where to put the screwdriver
Member number: 36
fg-mart
PostPosted: Fri Feb 11, 2011 5:49 am Up
Tennis ball trick wouldn't work on our cars and I don't think on any others lol. If I de-lock it then that would. Mean a full door respray?
martyn
PostPosted: Fri Feb 11, 2011 2:12 pm Up
That only works on old VW or Mercedes with a VACUUM type central locking system.
PostPosted: Fri Feb 11, 2011 2:57 pm Up
well, people can still break in your car by smashing the window anyway.....
fg-mart
PostPosted: Fri Feb 11, 2011 3:08 pm Up
id rather replace a window than replace a full door myself.
martyn
PostPosted: Fri Feb 11, 2011 3:10 pm Up
You dont need to break a window to get in to a locked 206 Wink
Even delocking it is a waste of time Laughing
