Latest: airmastertapes
Overall: 17133
Online Now [528]:
Visitors: 526
Members: 1
Today: 65543
Total: 106599148
Forums › The Car › 206 Talk › Front hub assembly
Front hub assembly
tyrone81
PostPosted: Sun Feb 13, 2011 5:18 am Up
Is the 180 and the 138 the same?
Peugeot 206 GTI 180.
Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere.
PostPosted: Sun Feb 13, 2011 5:20 am Up
They will be as in taking it apart. But different size callipers, discs and the 180 will have better springs. Think everything else is the same. Smile
tyrone81
PostPosted: Sun Feb 13, 2011 5:27 am Up
So the 180 calipers will fit the 138 hub? MOT soon so needing one. Only one 180 hub on ebay and guys wanting £60 , can get a 138 assembly for £30.
PostPosted: Sun Feb 13, 2011 5:29 am Up
I *think* so, but please wait for someone else to confirm this as I ain't 100% sure.
tyrone81
PostPosted: Sun Feb 13, 2011 5:36 am Up
Just relised the one on ebay doesn't have ABS.
PostPosted: Sun Feb 13, 2011 6:04 am Up
Thought ABS was on the driveshafts?
tyrone81
PostPosted: Sun Feb 13, 2011 6:18 am Up
On the back of the hub.
PostPosted: Sun Feb 13, 2011 8:04 am Up
Both GTi hubs are the same. 2.0 HDi hubs should be the same too.
