Latest: Puggingalong
Overall: 17129
Online Now [87]:
Visitors: 86
Today: 4998
Total: 100979593
Forums › The Car › 206 Problems › Leaking issues
Leaking issues
Rob2859
PostPosted: Sun Feb 13, 2011 7:57 pm Up
I realised today water is dripping in from the ariel. How can I actually stop it is it a case or replacing a rubber seal?
Second leak is quite bad. all the underlay on one side of the boot is soaking. There is moisture inside the rear light on the one side as well. Maybe its coming from there?
Goint to buy loads on silica packs because there is a lot of water on the inside of the screen in the morning.
Before anyone says it I did use the search but I failed Very Happy
PostPosted: Mon Feb 14, 2011 2:17 am Up
Common PSA problem for the last 20+ years.
Take the aerial base of the roof & a little clear silicone around the hole in the roof before reassembly will cure it Wink
Rob2859
PostPosted: Mon Feb 14, 2011 12:29 pm Up
Cheers. Don't fancy sealing up my rear lights tho Very Happy
PostPosted: Mon Feb 14, 2011 12:36 pm Up
have the rear lights got the seals on them were the bulb holder goes in, i think there is one on there iirc
Rob2859
PostPosted: Wed Feb 16, 2011 7:18 am Up
there is yes but I don't think the water is coming from there.
