Latest: tbafonso
Overall: 17130
Online Now [136]:
Visitors: 135
Today: 55219
Total: 103790970
Forums › The Car › 206 Problems › indicator flashing fast when i apply brakes
scottbear75
PostPosted: Thu Feb 17, 2011 4:42 pm Up
hi
help needed when im indicating to go left my indicator goes ok, when i press the brake it starts to go faster ,as soon as i release the brake it goes back to normal.
i have checked my brake lights, all lights working ok , so dont know whats wrong with it. (206 sw 03)
head gasket case
PostPosted: Thu Feb 17, 2011 4:43 pm Up
Dodgey wiring in the rear cluster by the sounds of it. Could be a earthing problem, or water got into the electrics.
Does the rear indicator go out, when you press the brakes?
scottbear75
PostPosted: Thu Feb 17, 2011 4:44 pm Up
no mate indicator light stays on
head gasket case
PostPosted: Thu Feb 17, 2011 4:50 pm Up
Make sure all the connections are sound.
Try softbooting the BSi as well
scottbear75
PostPosted: Thu Feb 17, 2011 5:42 pm Up
will do .
thanks
head gasket case
Rob2859
PostPosted: Thu Feb 17, 2011 8:15 pm Up
have you changed the bulb recently?
scottbear75
PostPosted: Fri Feb 18, 2011 9:55 am Up
no mate havent touched a thing
head gasket case
