Posted: Thu Feb 17, 2011 5:42 pm |
hi
help needed when im indicating to go left my indicator goes ok, when i press the brake it starts to go faster ,as soon as i release the brake it goes back to normal.
i have checked my brake lights, all lights working ok , so dont know whats wrong with it. (206 sw 03)
Posted: Thu Feb 17, 2011 5:43 pm |
Dodgey wiring in the rear cluster by the sounds of it. Could be a earthing problem, or water got into the electrics.
Does the rear indicator go out, when you press the brakes?
Posted: Thu Feb 17, 2011 5:44 pm |
Lee wrote: |
Does the rear indicator go out, when you press the brakes? |
no mate indicator light stays on
Posted: Thu Feb 17, 2011 5:50 pm |
Make sure all the connections are sound.
Try softbooting the BSi as well
Posted: Thu Feb 17, 2011 6:42 pm |
Lee wrote: |
Try softbooting the BSi as well |
will do .
thanks
Posted: Thu Feb 17, 2011 9:15 pm |
have you changed the bulb recently?
Posted: Fri Feb 18, 2011 10:55 am |
Rob2859 wrote: |
have you changed the bulb recently? |
no mate havent touched a thing
