Latest: Worthy967
Overall: 17143
Online Now [594]:
Visitors: 593
Today: 131952
Total: 115464994
Forums › The Car › 206 Problems › Various Problems - 206 GLX 1.6 2000
chris001
PostPosted: Fri Feb 18, 2011 3:57 pm Up
Hi guys,
I've had nothing but problems with this car since I picked it up for my girlfriend in December. The latest problems are the central locking, the car pulling to the left and a squeek coming from the rear driver side drum.
1. Central locking
When I go to lock the car it locks and the immedietly unlocks, sometimes this happens once and then locks ok the 2nd time however recently it keeps happen and will not lock at all. I have locked all the doors manually only to come back later and find all the doors unlocked! Any ideas
2. The car pulling to the left
I have taken it to quick fit to check the tracking, the guy put it up and showed me the tracking was fine and didn't need adjusting (he pointed out a few other things while it was up and sealed a blowing exhaust). In the end he said he couldn't charge me! as there was nothing wrong! Kind of a result but the car was still pulling. I swapped the front and back tyres to eliminate the wheels/tires and now it appears better but still pulling a bit. Not really sure where to start.
3. Sqweek from rear drum
Sounds like a problem on the rear drums, could be metal on metal type sqweeking. Went to take off the rear drums but it looks like you would have to hammer out a bit in the metal nut holding the drum on. I dont want to f**k up the nut so whats the best way to do this or does anyone have any other ideas.
The car has an MOT next month so need to get the serious issues sorted.
Cheers guys
Chris
Chris
sherman_2009
PostPosted: Fri Feb 18, 2011 4:03 pm Up
1 Are all doors closed
2 For the car pulling to the side it could be the air in the wheels i'll get that checked out aswell
3 Could be metal on metal best thing is to get new brakes put on
sorry about the spelling
Have a 206 LX 1.4
chris001
PostPosted: Fri Feb 18, 2011 4:10 pm Up
Yeah all the doors are closed, previously i have gone round and slammed all the doors and sometimes this worked and sometimes not. Can I isolate this to see if it is a particular door/lock??
Also I think the clutch release bearing is going - Start the car and there is a tapping, dip the clutch and it goes
I'm starting to hate this car!
Chris
PugJH
PostPosted: Fri Feb 18, 2011 4:19 pm Up
Easy fixes
1. solenoid in one of the door locking mech's, search door lock bouncing
2. Did he use a laser line??? Im sure i have read things about struts/suspension acting on the pulling
3. Rear drum, change the shoes, check the handbrake etc while your there.
WIP: Black 1.6 16v XSi
Beauté Noire
PugJH
PostPosted: Fri Feb 18, 2011 4:25 pm Up
and id say the tapping is the release bearing
Beauté Noire
chris001
PostPosted: Fri Feb 18, 2011 4:35 pm Up
Thanks for the quick reponses.
The guys checked the alignment with a laser and showed me it was within tollerance? I checked the tyre pressure all ok on all 4.
I'll checked the drums/handbrake an let you know.
Chris
sherman_2009
PostPosted: Fri Feb 18, 2011 4:37 pm Up
mmmmmmmmm intresting then!!!
Have a 206 LX 1.4
paulrushton
PostPosted: Fri Feb 18, 2011 4:43 pm Up
Brake caliper binding possibly. Take it for a spin and when you stop see if either alloy is warmer (don't touch the disc). If one warmer the caliper is sticking.
Peugeot 206 GTI HDI Black
chris001
PostPosted: Sat Feb 19, 2011 10:06 am Up
I tried to sort the central locking today - looked at other posting and people suggested the solonoid. Locked the car to see if any of the locks didn't move. all went down and then bounced up so thought it could be the solonoid in the boot. Unplugged the boot lock mech and tried the locks - smae problem! going to try the front doors next will let you know. If anyone has any other suggestions it would be appriciated.
Chris
Chris
PugJH
PostPosted: Sat Feb 19, 2011 1:01 pm Up
I dont think unplugging the mechs will work, the car will think its failed and bounce back, same as if the solenoid had gone.
But try and find out for me lol.
I have a spare solenoid here, but i dont know which side it is/cant remember, if you find out which one it is, let me know and i will see what side i have. £10 posted and its yours, cheap fix me thinks Very Happy
Beauté Noire
PugJH
PostPosted: Sat Feb 19, 2011 1:04 pm Up
or check these out and just replace both *depending on pin type and what not*
cgi.ebay.co.uk/PEUGEOT...4aa7f7672e
Beauté Noire
chris001
PostPosted: Sat Feb 19, 2011 1:25 pm Up
Yeah your right unplugging the mechs doesnt work - realised after disconnecting 4 doors and the boot. now its too dark to go any further tonight. how would i know which solonoid has gone?
Chris
PugJH
PostPosted: Sat Feb 19, 2011 1:32 pm Up
4door..... s**t.
have you looked at the actual mech, by taking door card off and doing remote locking?
Should find one that only moves half as much as the others, or moves slower, or instantly flicks back
Beauté Noire
chris001
PostPosted: Sat Feb 19, 2011 1:57 pm Up
yeah tell me about it!!!
I'll have a look at all the mechs tomorrow and let you know hopefully it will be obvious. thanks for the help (and quick responses!).
Chris
Chris
chris001
PostPosted: Sat Feb 19, 2011 4:24 pm Up
is there any way i can disable the central locking so i can lock the car while the system is playing up?
Chris
