Latest: Beduff1977
Overall: 17134
Online Now [687]:
Visitors: 686
Today: 67391
Total: 107727629
Forums › The Car › 206 Talk › BSI upgrade in/near Bolton?
PostPosted: Sat Feb 19, 2011 3:44 pm Up
Does anyone know of a garage or Auto electrician that can do BSI upgrades. Don't fancy paying Peugeot prices. Chorley Street Garage have been suggested by a car shop. Anyone ever used them for anything.
PostPosted: Sat Feb 19, 2011 3:48 pm Up
ooo, where abouts in Bolton are you mate? Dad lives in Radcliffe and down there a fair whack! Wink
Try Lee in Sheffield, he MIGHT be able to do it and will travel to you at a price, you could go to him or meet half way. Smile
PostPosted: Sat Feb 19, 2011 3:56 pm Up
I'm in Westhoughton, so fairly Central for Bolton, Wigan or Leigh
PostPosted: Sat Feb 19, 2011 3:59 pm Up
Haha, I spent about 6 years living on Liscard Street, Atherton. Wink Grandad lives in lowton, Dad in Radcliffe. Wink Shall keep my eye out for you next time I am down.
Give him a PM, he will still probs work out cheaper than a garage if he can do it: www.206info.co.uk/Your...e=144.html
PostPosted: Sat Feb 19, 2011 4:02 pm Up
Only Peugeot will do upgrades, no aftermarket place will touch doing updates. Even some Peugeot garages dont.
What are you wanting to do?
Upgrades and feature activation are two different things.
PostPosted: Sat Feb 19, 2011 4:18 pm Up
Thinking about the twin hazard switch, but I don't think the car has been serviced properly for a few years, so thinking that a tune up and general check over really. Had the car 3 weeks and finding tell tale signs that it was never looked after.
PostPosted: Sat Feb 19, 2011 4:24 pm Up
Well you can service it yourself Smile
I can't do BSI updates, but can turn features on that your BSI has the capabilities of
PostPosted: Sat Feb 19, 2011 4:32 pm Up
Doing the service. just didn't know if there was an easy way to tune the computer. At Rover, we used to have to connect to electronics to set idle and fuel/air ratio. I have a copy of PP2000 v20.14 but when it loads it says it won't run on my system.
PostPosted: Sat Feb 19, 2011 4:36 pm Up
Only people that will tune the ECU are remappers, normal garages won't do it.
v20.14 is a old version
PostPosted: Sat Feb 19, 2011 4:41 pm Up
Had v22.14 and that said same so I opted for earlier version to see if it ran on vista. I will look at getting it remapped. I'm going to put it in for pre MOT soon just to see how bad it actually is.
PostPosted: Sat Feb 19, 2011 4:42 pm Up
Pointless really having a 1.4 8v remapped, won't gain much for the amount it costs.
Do you have the interface for it?
PostPosted: Sat Feb 19, 2011 5:01 pm Up
Not yet, working on that one.
I'll just give it a good service and see where I go from there. I'll give you a shout if I need anything activating. Now I'm told I've got to put a light in the glovebox.....women
PostPosted: Sat Feb 19, 2011 5:04 pm Up
That only costs a fiver for the parts if you have the loom.
Look behind the glovebox and near the heaters, for two wires, one with a white connector and one with a brown one.
PostPosted: Sun Feb 20, 2011 4:32 am Up
You can't 'tune' modern engine. They simply don't go out of tune. Change all the servce items and that's as good as it will be without modifying it.
Are there going to be any ECU updates on a car that's been out of production for a few years?
Lecktorious
PostPosted: Sun Feb 20, 2011 4:36 am Up
Trade Rating: +59
IIRC PP2000 will only run on XP.
'98 Nile Blue 306 GTi 6
