Latest: tbafonso
Overall: 17130
Online Now [81]:
Visitors: 81
Today: 19078
Total: 102376516
Forums › The Car › 206 Talk › Running on a Propanol/Petrol mix?
schlash
PostPosted: Wed Feb 23, 2011 9:35 am Up
Greetings GentleFolks,
I was wondering if I can run a Propanol/Petrol mix in my 206 1.4L 2001.
I happen to have easy cheap access to Propanol (we use it as a solvent) and from what I can find out it should be similar to Ethanol but releasing slightly higher energy when it burns.
My concerns are as it is similar to Ethanol will it tend to cause corrosion in the fuel system and as it will tend to oxygenate the burn will the Lamda sensor be able to compensate.
Any good advice would be appreciated Smile
Best Regards,
Me.
PostPosted: Wed Feb 23, 2011 11:59 am Up
that's why you need engine conversion to run ethanol as fuel......
D4NTP
PostPosted: Wed Feb 23, 2011 12:03 pm Up
I thought you could run about 5% in a standard car.
M60SHW
PostPosted: Wed Feb 23, 2011 12:36 pm Up
more hasstle than its wearth imo anyway fuel carnt be that dear in israel can it??
Team, ST
Team, Gti 138 track slag
D4NTP
PostPosted: Wed Feb 23, 2011 12:47 pm Up
It is if your palestinion
PostPosted: Wed Feb 23, 2011 12:53 pm Up
even in US, petrol is cheaper than IPA.....
