Posted: Wed Feb 23, 2011 9:35 am |
Greetings GentleFolks,
I was wondering if I can run a Propanol/Petrol mix in my 206 1.4L 2001.
I happen to have easy cheap access to Propanol (we use it as a solvent) and from what I can find out it should be similar to Ethanol but releasing slightly higher energy when it burns.
My concerns are as it is similar to Ethanol will it tend to cause corrosion in the fuel system and as it will tend to oxygenate the burn will the Lamda sensor be able to compensate.
Any good advice would be appreciated
Best Regards,
Me.
Posted: Wed Feb 23, 2011 11:59 am |
that's why you need engine conversion to run ethanol as fuel......
Posted: Wed Feb 23, 2011 12:03 pm |
I thought you could run about 5% in a standard car.
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
Posted: Wed Feb 23, 2011 12:36 pm |
more hasstle than its wearth imo anyway fuel carnt be that dear in israel can it??
| Image removed due to size
Team, ST
Team, Gti 138 track slag | |
Posted: Wed Feb 23, 2011 12:47 pm |
Shaw-pug wrote: |
more hasstle than its wearth imo anyway fuel carnt be that dear in israel can it?? |
It is if your palestinion
Posted: Wed Feb 23, 2011 12:53 pm |
even in US, petrol is cheaper than IPA.....
