Latest: Beduff1977
Overall: 17134
Online Now [577]:
Visitors: 576
Today: 35871
Total: 107971201
Forums › The Car › 206 Problems › temp sensor
temp sensor
Rusky
PostPosted: Fri Feb 25, 2011 8:17 am Up
im believe a temp gauge with a mind of its own could be the senor can anyone tell me the right one to get for a 1999 1.4lx auto
im liking this little toy
PostPosted: Fri Feb 25, 2011 9:23 am Up
Euro Car Parts will list them. They are green.
Bassline_Toad
PostPosted: Fri Feb 25, 2011 10:03 am Up
Does it shoot up randomly?
Mine does that!
I've changed the sensor and it still does it (very occasionally now though, I must admit).
Rusky
PostPosted: Fri Feb 25, 2011 6:17 pm Up
Ya it does and it was fine til I tried to bleed coolant and flush matrix
mdstone
PostPosted: Thu Mar 03, 2011 7:16 am Up
Is this the temp guage that appears on the dash? Mine has been at 42degrees C for a while now so i'm guessing it's naff. How do you go about repacing it? Is it located in the wing mirror?
Peugeot 206 GTi
Rusky
PostPosted: Thu Mar 03, 2011 7:28 am Up
mines got a mind of its own should see me look like frosty the snow man it gets so cold no heat at all blower works just no heat heat on one of the matrix pipes but no heat
PostPosted: Thu Mar 03, 2011 4:57 pm Up
Passenger wing mirror, unclip / remove the mirror glass.
Sensor is clipped in, you really need a soldering iron & heat shrink to attach the 2 wires of the replacement sensor.
