Latest: Beduff1977
Overall: 17134
Online Now [1185]:
Visitors: 1184
Today: 198671
Total: 110053094
Forums › The Car › 206 Problems › Engine light :(
Engine light :(
MutilateTheDead
PostPosted: Sat Feb 26, 2011 7:59 am Up
Just been cleaning my engine bay and after i had finished i went to start the car and drive off but before i did when the car was sitting idle it was struggling to hold the 1000rpm it usually does and juddered a lot (felt like it was going to stall but didn't) And then noticed the 'amber engine light' was flasing!! Daren't drive off until i know what it is!? Any ideas??
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
PostPosted: Sat Feb 26, 2011 8:00 am Up
What with? ? ?
MutilateTheDead
PostPosted: Sat Feb 26, 2011 8:04 am Up
Just a cloth, it is wet where i am though, and some water did trickle in!
PostPosted: Sat Feb 26, 2011 8:10 am Up
Where did the water trickle in?
There's plenty of electrical bits under the bonnet that wont be happy getting wet Wink
MutilateTheDead
PostPosted: Sat Feb 26, 2011 8:13 am Up
Straight down the middle, didn't think it was on much, will it sort itself out over time Confused
MrrNoName
PostPosted: Sat Feb 26, 2011 8:18 am Up
cant hurt to let it fully dry out and see if it goes away Razz did it drip on any sensors?
MutilateTheDead
PostPosted: Sat Feb 26, 2011 8:27 am Up
I wouldn't even know here they are haha, i know not to f**k about with the engine again when its wet!
MutilateTheDead
PostPosted: Sat Feb 26, 2011 9:04 am Up
The light is no longer flashing but it is still on constantly!
MutilateTheDead
PostPosted: Sat Feb 26, 2011 10:15 am Up
Got bored so polished and waxed the beast, left bonnet open facing VERY strong wind to try and dry the engine bay out a little and it worked Smile :) Cheers MrrNoName Smile
SDK206
PostPosted: Sat Feb 26, 2011 1:25 pm Up
The light flashing means its detected a misfire, on constant will just be telling you its stored codes.
Has the light now turned off?
If in doubt, drop a cog and put your foot down Smile
MutilateTheDead
PostPosted: Sat Feb 26, 2011 7:52 pm Up
Yeah its turned off now, i think the engine did misire because water trickled into the engine bay, feels fine now Smile Thanks guys Smile
