Latest: eltel666
Overall: 17146
Online Now [66]:
Visitors: 65
Today: 16282
Total: 116238979
Forums › The Car › 206 Talk › Throttle Position Sensor ( now with video of problem)
Go to page 1, 2, 3, 4  Next
leigh_boy
PostPosted: Sun Mar 06, 2011 3:52 pm Up
any 1 had a problem with the Throttle Position Sensor ?
if so what problems did you experiance?
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Sun Mar 06, 2011 4:03 pm Up
The car should still run because it can use the map sensor to detect throttle position/load.
I'm sure the ECU light would be on though if it was faulty.
leigh_boy
PostPosted: Sun Mar 06, 2011 4:08 pm Up
..my engien management light doenst actually seem to come on when it detects a problem lol.
engein light didnt come on when it failed on my 1.6 either.
but only thing i can put down to the car backarowing when i hold rpm.
*DEAD*206 Gti 138
PostPosted: Sun Mar 06, 2011 4:19 pm Up
Have you made sure the map sensor is clean?
leigh_boy
PostPosted: Sun Mar 06, 2011 4:30 pm Up
ye map sensor cleaner, same with throttle body, cam sensor change, crank sensor changed, temp sensor changed , plugs changed , knock sensor changed. running out of ideas now
*DEAD*206 Gti 138
PostPosted: Sun Mar 06, 2011 5:42 pm Up
My throttle position sensor was knackered, revs were all over the place.
You could put your foot down and the revs wouldn't increase then all of a sudden it would shoot off.
leigh_boy
PostPosted: Mon Mar 07, 2011 9:15 am Up
does any one have tps sesnsor resistace values for open , close, and part throttle?
*DEAD*206 Gti 138
PostPosted: Mon Mar 07, 2011 1:27 pm Up
With ignition on it should be either 0v or 5volts depending which wire you are probing.
Between 0.6-0.8volts with ignition on and throttle valve closed
Between 4-4.6volts with igition on and throttle valve fully open
leigh_boy
PostPosted: Mon Mar 07, 2011 1:40 pm Up
cheers that sort of help any idea on how many ohns?
*DEAD*206 Gti 138
PostPosted: Mon Mar 07, 2011 1:44 pm Up
Not sure on what the reading should be but the resistance should gradually increase and decrease as you open and close the throttle, it shouldn't be jumping all over the place.
leigh_boy
PostPosted: Tue Mar 08, 2011 4:40 am Up
www.youtube.com/watch?v=kuGmzdz0HlM
*DEAD*206 Gti 138
Kersh
PostPosted: Tue Mar 08, 2011 4:44 am Up
that looks to be definitley the TPS lol, ive got a used one sitting in my garage if youre interested Smile
Member number: 36
leigh_boy
PostPosted: Tue Mar 08, 2011 5:09 am Up
can you explain how you came to that conclusion?
and how much is it? and is it for a gti 138?
*DEAD*206 Gti 138
Kersh
PostPosted: Tue Mar 08, 2011 5:40 am Up
well if your holding the throttle at one spot and the revs are jumping like that then there's clearly an issue with the signal, that or maybe air leak etc, its hard to tell without a fault code.
its from a 51 plate GTi 138 pre-plexed
£30 posted, thats ALOT cheaper than what they cost new Wink
Member number: 36
leigh_boy
PostPosted: Tue Mar 08, 2011 5:45 am Up
there is fault codes but i havent had time to clean them up and check agian recently since doing the work non of them were tps tho.
hmm i can get one here: cgi.ebay.co.uk/ws/eBay...K:MEWAX:IT for £22
*DEAD*206 Gti 138
Page 1 of 4
