Latest: tbafonso
Overall: 17130
Online Now [38]:
Visitors: 37
Today: 23916
Total: 103815436
Forums › The Car › 206 Problems › Sunroof Question
Sunroof Question
Phil_G
PostPosted: Wed Mar 09, 2011 9:31 am Up
I am just dealing with the last of a series of annoying problems. The issue I have is that the sunroof (panoramic) is quite temperamental. It sometimes only goes back a few inches, other times opens fully. It also consistently fails to close all the way. It closes enough to be watertight, but not enough to stop wind noise.
I have resigned myself to removing the headlining next weekend to find out thats going on. Initial thoughts are it is one of three things:
Sunroof motor needs replacing (about £25)
Sunroof cables need replacing (about £35)
Whole sunroof needs replacing (£130)
Any ideas which of those it could be given the symptoms (crosses fingers for motor)
Cheers
-- Phil
1999 1.4 LX in Green
2002 1.6 cc in silver
Danw_VVT
PostPosted: Wed Mar 09, 2011 9:35 am Up
my guess would be either of the first two mate. i couldnt see the whole thing needing replacing.
PostPosted: Wed Mar 09, 2011 9:39 am Up
Gonna be lack of use & lack of grease Wink
Phil_G
PostPosted: Wed Mar 09, 2011 9:57 am Up
Now that is some good news. Do you reckon the motor will need lubing, or just the runners (hidden question, is there any way I can get out of removing the roof lining?)
PostPosted: Wed Mar 09, 2011 10:03 am Up
No idea, never done a 206 sunroof Laughing
Worked on a 405 electric sunroof, lack of grease / use.
Phil_G
PostPosted: Wed Mar 09, 2011 2:32 pm Up
Thanks for the advice, looks like I will have to play it by ear.
Cheers
-- Phil
MALLE
PostPosted: Mon Jul 11, 2011 10:02 am Up
hi i worked on mine i had to rempve the sun visors and lamp an just working in the area of the lamp and the is alan key hole tht i use to move the motor manually after moving it a few times the motor got free and worked great so i made a small hole in the liner under said aln key way so i could close the roof if i got any problems in the future without moving the liner my problem now is the the shuttles that move the roof are broken so i dont have anything holding the roof inplace i want to risk a dismantle\fix so i am looking to see if anyone has a dismantle guide i will keep u posted in the how to guide as to my success .
want to turbo charge
