Latest: eltel666
Overall: 17146
Online Now [83]:
Visitors: 82
Today: 14593
Total: 116237299
Forums › The Car › 206 Talk › convert standard heater to climate control from GTI
pilot300
PostPosted: Sat Mar 12, 2011 11:40 am Up
hi there
I have a 2000 'X' reg 206 2.0 HDI I currently have a standard heater control unit but want to know if its possible to fit the digital climate control from the GTI, I have searched the net but can't find any info.
If its possible what do i need to do? Also my MDF only displays the time atm, if i get the GTI MDF can i get any other on board computer information?
thanks
Duncan
PostPosted: Sat Mar 12, 2011 11:41 am Up
do you have manual air con?
Lewis1304
PostPosted: Sat Mar 12, 2011 11:42 am Up
Ive done this, more hassle than its worth mate Smile it looks cool yes but manual is evidently better.
Lewis
206 1.6 16v, Nimrods, Full SP Kit, 3 Stage Valve Cut Head, 4-1 Manifold With Decat, Pug Sport Backbox, Vibe Speakers, HIDs In Projectors, DVD screens & Sub Smile
PostPosted: Sat Mar 12, 2011 11:43 am Up
Lewis
Its only because most people don't understand how climate control really works & then moan when it turns itself on Wink
pilot300
PostPosted: Sat Mar 12, 2011 11:44 am Up
is manual honestly better? what did you have to do in order to change it? my manual control unit has an a/c button yes.
Duncan
Lewis1304
PostPosted: Sat Mar 12, 2011 11:51 am Up
yehhh do u know what temp you want to be or do u know if you want hot or cold? manual is better Smile
You need the whole climate control box, panel, sensors and wiring loom.
Lewis
PostPosted: Sat Mar 12, 2011 11:58 am Up
If the climate system is set to a low temp & its hot inside the passenger cabin it will turn itself on to try & cool the car.
If the climate system is set to a high temp & shock horror it's cold inside the passenger cabin then guess what, it will turn itself on to try & heat the car up.
Set it to 21 deg C & leave it on AUTO during this time of year.
Come the summer ill have it on 14 deg C & AUTO Cool
The climate system get's it's temp reading's from the outside temp sensor on the passenger wing mirror & also the cabin temp sensor behind the slotted grill on the passenger airbag.
pilot300
PostPosted: Sat Mar 12, 2011 12:10 pm Up
i understand how climate control works, lol im to work out how to swap it into my pug. Is the wiring in the Pug's universal so its just a case of plugging it in, or will i need a new loom etc.
Duncan
Ash
PostPosted: Sat Mar 12, 2011 1:00 pm Up
You need a new AC pump as well last time I checked.
