Latest: jtq4u
Overall: 17141
Online Now [79]:
Visitors: 78
Today: 13049
Total: 113982450
Forums › The Car › 206 Problems › Clutch Judder [Brake Judder]
Abzynthe
PostPosted: Mon Mar 14, 2011 1:32 pm Up
East Area Rep - Abzynthe
Took my car to the garage today as the clutch cable has stretched. After a road test, they said that i would need a new clutch kit as I have brake judder?
The car seems fine to me, except the clutch pedal slipping every now and then.
What is brake judder and what does it have to do with the clutch?
PostPosted: Mon Mar 14, 2011 1:33 pm Up
are you sure they are not saying clutch judder?
Abzynthe
PostPosted: Mon Mar 14, 2011 1:34 pm Up
He definately said brake judder, but he seemed like he was just one his way out when i went to collect it so he might have meant clutch judder.
-Dave-
PostPosted: Mon Mar 14, 2011 1:39 pm Up
Trade Rating: +36
I thought brake judder was caused by warped disc's or pad's, Stuff like that. Correct me if I'm wrong but I have never heard brake juddering caused by clutch issue's.
Edit - Just seen above post's
Ex 206 Owner.
Abzynthe
PostPosted: Mon Mar 14, 2011 1:49 pm Up
So is clutch judder bad?
The clutch is only 12k miles old Sad and i cant take it back under warranty as the whole subframe etc is from another car Sad
Ste
PostPosted: Mon Mar 14, 2011 1:54 pm Up
Staff - Ste
Clutch Judder is caused by the clutch components and flywheel not meeting concentrically. The friction surfaces rub concentrically causing a low frequency vibration that is transmitted to the car via the engine/gearbox mountings and drive shafts. Causes can be
1) Mis-aligned clutch
2) Clutch wear/broken 'finger' springs
3) Condensation on the flywheel (usually happens on colder nights in which case judder should only last until the condensation has evaporated)
4) Contamination on the clutch such as oil from a leaking gland.
Case 1 will require the clutch to be re-aligned
Case 2 will require a new clutch
Case 3 may happen frequently on colder mornings, but judder will disappear 5 mins into driving.
Case 4 Replacement of the clutch plates
Driving continuously with judder may cause damage/increase wear to engine and/or gearbox components. If judder persists take your vehicle to a garage as soon as possible.
Taken from: wiki.answers.com/Q/Wha...z1GbMNi6Aj
The Cars:
-Dave-
Trade Rating: +36
I don't know a lot about clutch judder but found thid while trying to educate myself, It may help.
www.ehow.co.uk/about_6...blems.html
Ex 206 Owner.
-Dave-
PostPosted: Mon Mar 14, 2011 1:55 pm Up
Trade Rating: +36
Laughing
Just read that myself.
Ex 206 Owner.
Abzynthe
PostPosted: Mon Mar 14, 2011 2:17 pm Up
Thanks guys Smile
-Dave-
PostPosted: Mon Mar 14, 2011 2:25 pm Up
Trade Rating: +36
Just hope it help's, Suck's with all the hard work you have just put into the engine.
Ex 206 Owner.
panason1c
PostPosted: Tue Mar 15, 2011 3:20 am Up
"Case 1 will require the clutch to be re-aligned"
Out of curiosity, exactly how do you re-align a clutch?
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
panason1c
PostPosted: Tue Mar 15, 2011 3:26 am Up
Out of curiosity, exactly how do you re-align a clutch?...surely the clutch is self-aligned by the spigot shaft passing thru its centre?.
Clutch judder can also be caused by the friction plate becoming warped
BMW K1200RS
PostPosted: Tue Mar 15, 2011 3:30 am Up
Is this the clutch from Liams old pug then?! I only had one fitted recently before the engine went on me!
regarding the warranty, will they know about the subframe being different etc?! Laughing
Abzynthe
PostPosted: Tue Mar 15, 2011 8:36 am Up
Yeah its Liams clutch, but thats new aswell.
If I had a recept for your clutch i could give it a go, but I certainly cant with Liams as its a different car lol.
PostPosted: Tue Mar 15, 2011 8:40 am Up
Sorry I beleive my mum didnt post the paperwork when i asked for your address that time! I think the receipt was with it. Ill make her post them all tomorow, can you pm me your address again?
