Latest: Beduff1977
Overall: 17134
Online Now [1768]:
Visitors: 1767
Today: 128109
Total: 108063267
Forums › The Car › 206 Problems › Clutch Judder [Brake Judder]
Go to page Previous  1, 2
Abzynthe
PostPosted: Tue Mar 15, 2011 8:41 am Up
East Area Rep - Abzynthe
PM'd Smile
Norvvv
PostPosted: Tue Mar 15, 2011 11:51 am Up
I also have clutch judder! Sad only for a short distance between the biting point and mid clutch. I got a new clutch cable fitted however that didn't work, since shown it to my mates dad owns a garage and says it will need a new clutch :/
2001 1.4lx
PrePlexed 5 door.
Abzynthe
PostPosted: Tue Mar 15, 2011 11:55 am Up
The only "Judder" I get is at exactly 50mph. Other than that, it all seems fine!
Im going to get a new cable fitted asap as its stretched, but im going to wait a while for the clutch as they are quite expensive :S
panason1c
PostPosted: Tue Mar 15, 2011 1:11 pm Up
Sounds more like a wheel balancing issue to me based on the above.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
Abzynthe
PostPosted: Tue Mar 15, 2011 6:00 pm Up
Nope had 4 new tyres fitted, fully balanced and tracking done. You should have seen what it was like before I got that done lol, To go straight the steering wheel was upside down, if you let go while going forward it pulled to the left, and in reverse it pulled to the right.
Now its all good except the wobble at 50mph.
From what Ste put,
Quote::
The friction surfaces rub concentrically causing a low frequency vibration that is transmitted to the car via the engine/gearbox mountings and drive shafts.
It feels like the drive shafts.
danlouiee
PostPosted: Wed Apr 13, 2011 4:33 pm Up
So would this be like when you brake and put the clutch in the car still wants to drive and try's to stall itself but sorts it out?..if that makes sense? I've just had a new clutch and l/hand drive shaft fitted?!
Page 2 of 2
