Online Now [180]:
Visitors: 179
Today: 54070
Total: 138910546
Forums › The Car › 206 Talk › What bolt is this?
What bolt is this?
PostPosted: Thu Mar 24, 2011 10:51 am Up
Simple question, probably straight forward answer. It's located on the wishbones and are the same as the four bolts holding the rear axle on.
It's a torx bolt, but the opposite like you need a female torx socket or something. I haven't come across them before and have already rounded off one socket Sad
PostPosted: Thu Mar 24, 2011 11:08 am Up
I know the ones you mean, there are also some holding on the front ARB.
Not sure of the size off the top of my head though Sad
PostPosted: Thu Mar 24, 2011 11:10 am Up
I don't even know what they are called Sad a 10mm socket fits over them perfectly, but as soon as you stard to turn it just rounds off as there isn't enough surface area between them. At least that what happened to me on the axle.
PostPosted: Thu Mar 24, 2011 11:18 am Up
You got a haynes manual?
It should tell you in there.
Antknee
PostPosted: Thu Mar 24, 2011 11:22 am Up
dunno about quality but these are cheap Razz
PostPosted: Thu Mar 24, 2011 11:23 am Up
Just had a look and it says "losen the four bolts" and thats it Sad it sounds so simple. I'm starting to think it is actually a normal socket..
PostPosted: Thu Mar 24, 2011 11:27 am Up
What are cheap? Laughing
Antknee
PostPosted: Thu Mar 24, 2011 11:35 am Up
LOL oops forgot to put the link in Laughing
Was just having a look on ebay for female torx sockets, turns out they are a real thing Razz
PostPosted: Thu Mar 24, 2011 11:36 am Up
I've got the socket in my tool kit.
I'm planning on doing some car stuff this evening.
If you remind me around 6pm I can check the size for you.
PostPosted: Thu Mar 24, 2011 11:39 am Up
Ah ok, cheers guys Smile I willl have to invest into them, I have dozens of different types of sockets but not one like this.
PostPosted: Thu Mar 24, 2011 11:41 am Up
they are E socket
PostPosted: Thu Mar 24, 2011 11:43 am Up
Cheers seabook, I would persume it's E10? as a 10mm soket fits it.
sorry but i got no idea about the sizing Sad
you better wait for CD-vRS's answer
PostPosted: Thu Mar 24, 2011 11:45 am Up
Ok no worries thanks
PostPosted: Thu Mar 24, 2011 11:50 am Up
Service box doesn't give sizes Rolling Eyes
Send me a PM later & I'll check.
