Posted: Thu Mar 31, 2011 5:25 am |
I have noticed that when I park up and turn the engine off and remove the key the engine is still running. It doesn't happen everytime but when it does happen it the engine continues to run for a few seconds and then switches off. What is this - is it going to lead to a bigger problem. Many thanks for your advice N
Posted: Thu Mar 31, 2011 5:36 am |
is it the dw8 1.9 engine?
Posted: Thu Mar 31, 2011 5:45 am |
fuel cut off solenoid. Don't know where it is located
Posted: Thu Mar 31, 2011 6:00 am |
Rob2859 wrote: |
fuel cut off solenoid. Don't know where it is located |
normaly on the pump.
Posted: Thu Mar 31, 2011 6:18 am |
Its strange I had that problem a few times but then it was fine after. I think it got water logged.
Posted: Thu Mar 31, 2011 6:20 am |
Wrong bulb in the rear cluster for stop / tail can cause ignition faults
1.4 GLX in profile, its gonna be a TU3 lump.
Posted: Thu Mar 31, 2011 8:07 am |
that happened to my 306 and turned out it was head gasket :/
Posted: Thu Mar 31, 2011 8:32 am |
MrBSI wrote: |
1.4 GLX in profile, its gonna be a TU3 lump. |
Send +12v down the side light wire and the ignition comes on
Posted: Thu Mar 31, 2011 8:36 am |
Lee wrote: |
MrBSI wrote: |
Send +12v down the side light wire and the ignition comes on  |
Originally found out by Ricky / Porndog all those years ago
Posted: Thu Mar 31, 2011 9:14 am |
Thanks for your replies - my car is indeed a 1.4 GLX. You mentioned a light bulb? I did have a rear light out a couple of weeks ago and the bulb was replaced - could the engine running fault be down to that then? Also I have noticed when I drive in the dark my tail light is permenantly on too.....
Posted: Thu Mar 31, 2011 9:19 am |
nicholad wrote: |
Thanks for your replies - my car is indeed a 1.4 GLX. You mentioned a light bulb? I did have a rear light out a couple of weeks ago and the bulb was replaced - could the engine running fault be down to that then? Also I have noticed when I drive in the dark my tail light is permenantly on too..... |
Bingo
Make sure the stop / tail bulb is the correct twin filiment 5w21 type & its fitted the correct way round.
Posted: Thu Mar 31, 2011 9:54 am |
gotta love an easy fix
on the leci tricks, if you turn the hazard switch round in a nova 14sri you can bump the car and it runs
Posted: Thu Mar 31, 2011 9:59 am |
Didz wrote: |
on the leci tricks, if you turn the hazard switch round in a nova 14sri you can bump the car and it runs  |
Thats old school Vauxhall.
There is a similar one for the first generation Vectra but I aint posting it up on a public forum
Reminds me of the first generation Peugeot / Citroen alarm & immobiliser system, that was so easy to bypass in seconds
Posted: Thu Mar 31, 2011 1:21 pm |
Lee wrote: |
MrBSI wrote: |
Does this mean we can all go and hotwire a 206?
Posted: Thu Mar 31, 2011 1:25 pm |
mdstone wrote: |
Lee wrote: |
MrBSI wrote: |
Does this mean we can all go and hotwire a 206? |
Nope. Immobiliser cuts in.
