Latest: ArtistKS
Overall: 17145
Online Now [57]:
Visitors: 56
Today: 5679
Total: 115994183
Forums › The Car › 206 Talk › LEDs in Phase 2 Rears
Andrew
PostPosted: Thu Mar 31, 2011 10:10 am Up
Being as I am going to take part in Howeys group buy for Osram nightbreakers for my front lights, I want the rears to match
heres my shopping list:
Rear/Stop P21/5W
Rear Indicator P21W
Reverse Lights P21W
License Plate W5W
3rd Brake W5W
Is this all correct fitment? My main question is will I need resistors on any of these? Thanks for your time
My 206 thread
www.detailedbyandrew.com
PostPosted: Thu Mar 31, 2011 10:14 am Up
I'm unsure.
just posting to say I saw you run the 1/4 mile Smile
Andrew
PostPosted: Thu Mar 31, 2011 10:17 am Up
The pain staking slowness! at least i put my mate and his fezza in place
I watched you towards the end of the day, did you see the lad in the black MG? ouch!
My 206 thread
MrrNoName
PostPosted: Thu Mar 31, 2011 10:19 am Up
due to the fact that indicators work on resistance you will need a resistor with those LED indicator bulbs or they will flash too fast (as if you have a bulb out)
Andrew
PostPosted: Thu Mar 31, 2011 10:23 am Up
Is it just the indicator that would require a resistor then? If so I will skimp on the indicator lol
My 206 thread
PostPosted: Thu Mar 31, 2011 10:25 am Up
Yeah 20 seconds...
Good on you for having a go though.
Yep, nasty crunch! Driveshaft or gearbox.
There was an oil spill right at the end of the track on one of my runs, went over it at 90mph... scary!
Andrew
PostPosted: Thu Mar 31, 2011 10:31 am Up
Yeah 20 seconds...
19! In twelve months when I can afford to insure it I would like a cat back exhaust, cold intake and a remap and see if with better take off as well i can shave a couple seconds off Smile
Enjoying the VRS then? Smile
My 206 thread
PostPosted: Thu Mar 31, 2011 11:15 am Up
I have heard that you should use the Red LED's with Red lenses, Im not sure why tho
Andrew
PostPosted: Thu Mar 31, 2011 11:25 am Up
On which light mikey, reverse and indictor?
My 206 thread
PostPosted: Thu Mar 31, 2011 11:40 am Up
Red LED's mate in tail lights with red lenses
Andrew
PostPosted: Thu Mar 31, 2011 11:53 am Up
Has LED's in phase twos been done before? Ive just been told it wont make any noticeable difference
My 206 thread
Matt
PostPosted: Thu Mar 31, 2011 12:39 pm Up
Trade Rating: +32
Won't it just make the red bits shine pink lmao.
PostPosted: Thu Mar 31, 2011 1:01 pm Up
If you put the white LED's in behind the red lense they do look a bit pink. I think someone has done it with the third brake light. I'm not sure if standard LED will be bright enough, you could try SMD LED. They are a lot brighter. I'm saving the pennies to buy the P21/5 ones for my rears
Andrew
PostPosted: Thu Mar 31, 2011 1:02 pm Up
I think I'm going to stay standard, too much money and effort with resistors on something that I won't really be looking at for something I am told wont make a difference
My 206 thread
PostPosted: Thu Mar 31, 2011 1:05 pm Up
I've got some white led already, I will try them in the indicators over weekend and see if it makes a difference
