Latest: morgan20
Overall: 17135
Online Now [339]:
Visitors: 338
Today: 61155
Total: 110772341
Forums › The Car › 206 Problems › I think my car is dying :(
alanamh
PostPosted: Tue Apr 12, 2011 11:56 am Up
Cut a long story short
A few months ago my car steering wheel starting shaking as I drove, I could hardly control it on the road so took it to local garage, said I had 2 misshaped tires at front and needed 2 new ones (the old ones had been on for 7 years) so had 2 new pirellis fitted and steering was fine. Took it back a few days later as tracking was out, got them to re set tracking and everything was fine again. However I have been back with the 'tracking' several times now and I know it shouldn't be going out so ofter. Decided to try another garage to get a second opinion and they have no idea what to suggest. Every time the tracking gets reset as soon as it goes on the road it goes out again. I AM STUCK and alot of money out of pocket, someone please help me the car is virtually un drivable at the mo with the steering
Quarmbo
PostPosted: Tue Apr 12, 2011 11:58 am Up
Virtually undriveable because of tracking? Really?
How bad are you talking? My trackings out on my gay-a and still drives fine.
Ford SportGay-A
Quarmbo
So it pulls to one side? Which side? How severe?
Ford SportGay-A
alanamh
PostPosted: Tue Apr 12, 2011 11:59 am Up
to the left, really sharply and quickly
MrZiggerz
PostPosted: Tue Apr 12, 2011 12:03 pm Up
Get a third opinion from another garage?
PostPosted: Tue Apr 12, 2011 12:04 pm Up
just change the track rod...?
PostPosted: Tue Apr 12, 2011 12:05 pm Up
im no expert but steering rack maybe? im sure someone on here can shed some more light
Ste
PostPosted: Tue Apr 12, 2011 12:07 pm Up
Staff - Ste
Also check your balljoints, I know of a car that was pulling sharply and without warning with perfect tracking and it was down to a totally trashed balljoint lol. (No it wasnt mine)
The Cars:
cartoonhead
if the tracking is being done and then the car is moved and it's out of track again i'd check all the front Ie wishbone ball joints , track rod ends , wheel bearings
Andy180+
PostPosted: Tue Apr 12, 2011 12:10 pm Up
my money would be on a bottom arm by the sounds of it, best get it check out
jase123
PostPosted: Tue Apr 12, 2011 12:14 pm Up
is it a constant pull to the left? or is it rendom? more like a skip to the left? it is french and bushes do tend to wear out quit often. i had a horrible skip to the left on my 180 that turned out to be the bottom arms. take it to wilco motorsave as they do a free suspension test and will get a bar and check all the suspect bushes
Signature removed due to size
PostPosted: Tue Apr 12, 2011 12:25 pm Up
If you are getting the tracking done and then it is out again, obviously the garage don't know what they are doing or saw you coming. After the second time of going back, they should have realised that something else was wrong and began investigating deeper.
How many degrees is the tracking moving by? Are the garage telling you it's the tracking, or are you just guessing that as it's pulling? You say the last set of tyres were on for 7 years, how many miles had your car done in that time? Was it off the road, if so for what reason? Just trying to discover if there are any other circumstances that may cause the car to pull. Just because it's pulling, doesn't mean it's the tracking.
Quarmbo
PostPosted: Tue Apr 12, 2011 12:40 pm Up
Get the car up on a jack and see if you can wiggle a wheel (holding it quarter to 3 etc)
Ford SportGay-A
alanamh
PostPosted: Tue Apr 12, 2011 3:35 pm Up
steering rack has already been changed, suspension is fine. not sure about the old tyres as i only bought it last may but had done about 41k. the garage said they will investigate it further for me they havent charged me for the times ive gone back so i know they aren't ripping me off. and its a constant pull to the left, like if i dont steer it i'll end up on the curb!!
PostPosted: Tue Apr 12, 2011 3:45 pm Up
probably bended bottom arm or something similar then
