Latest: tbafonso
Overall: 17130
Online Now [117]:
Visitors: 116
Today: 10773
Total: 104160783
Forums › The Car › 206 Problems › Ticking noise, then idle revs drop!
sampo85
PostPosted: Fri Apr 22, 2011 9:08 am Up
Before I get the usual answer, yes I've tried a search, but to no avail.
So, when I am at a stand still, my engine idles just below 1000rpm. Thats fine.
But every four or five seconds I seem to hear a "tick" noise and the revs drop by 50 to 100 revs. Just enough that the gear knob rattles like it does when you stall!
Heres a clip to show you what I mean:
Sound is quite quiet, but on 18 seconds, you can clearly hear the "tick" and see the revs drop.
It also seems to want to stall quite often after just starting up if I come to a stop (like when reversing and turning, or waiting at a junction) and yet my foot is fully depressing the clutch at the time!!
Anyone got any ideas as to what is happening and what could be done about it?
Ali_H
PostPosted: Fri Apr 22, 2011 9:11 am Up
Checked the idle control valve?
kurtis wrote:
sampo85
PostPosted: Fri Apr 22, 2011 9:12 am Up
Sorry, complete dummy when it comes to this, how would I do that, and what would I be looking for Al?
PostPosted: Fri Apr 22, 2011 9:22 am Up
Aircon on or off?
Checked the oil level with the dipstick?
Being the 16 valve version of the 1.4 lump it has the w**ky VVT system fitted as well.
sampo85
PostPosted: Fri Apr 22, 2011 9:28 am Up
Air con - off
Oil level - fine!
deanparkr
PostPosted: Fri Apr 22, 2011 12:09 pm Up
I had the same symptons once and it turned out to be a faulty Injector number 4
2002 1.4LX
