Latest: Beduff1977
Overall: 17134
Online Now [1376]:
Visitors: 1375
Today: 126604
Total: 108061764
Forums › The Car › 206 Problems › Electrical/ECU fault
dainbramaged01
PostPosted: Sun Apr 24, 2011 6:06 am Up
Ill start from the beginning to get everyone upto speed.
The thurst bearing in my clutch had gone i own a 2.0 Hdi Turbo 2002 model 206.
Whilst stripping everything down one afternoon i called it a day after taking the starter motor off. then realised the windows were still down.. DOH!
So with a friend i reconnected the battery to wind them up and the startmotor wires were arking off the engine block... Ooops i thought well sort that when we build it back up.
Sure enough we came back to this point turned the key and got nothing but the coolant fan running as if it was the starter motor?
Puzzled completely by this as i know very very little about electrics i checked countless times all the connections they are all good, earth strap is solid on the chassis all fuses are fine. i even took starter motor back and got it tested and thats all fine.
At this point i was lost my other friend who is a sparky checked all connections and found with his multi meter no power was getting to the starter motor from the battery when i turned the key but couldnt figure out why?
Now everytime i turn the key to start it the coolant fan wizzes round and i release the key i get a ticking noise from the ECU as if its trying to reset itself so again my sparky friend tried to find a way of reseting it by pushing a button on the inside of the ECU control panel.
And now i turn the key its even worse im at a complete loss i have no idea what to do next. Can anyone offer some advice or even suggest what to do next.
Cheers and sorry for dragging the story out.
PostPosted: Sun Apr 24, 2011 6:11 am Up
Did you shut the BSI down / reboot it correctly?
You cant just disconnect / reconnect battery leads of a multiplexed 206 like this!
Your dealing with a software driven computer brain that controls ALL the cars electrical systems over a digital CAN VAN network!
Shut the BSI down correctly, check the BM34 fuse box & also the BSI fuse box & cross your fingers its a blown fuse.
If you have fried the BSI unit then its break the vaseline out & bend over time Laughing
dainbramaged01
PostPosted: Sun Apr 24, 2011 6:17 am Up
Ok this is sound stupid but where can i find the BSI and how can i reboot it properly?
If this fails then apart from the vaseline what else needs to be done?
PostPosted: Sun Apr 24, 2011 6:22 am Up
BSI lives behind the flap to the right of the drivers knee.
Turn the plastic screw with a coin then lift up / unclip the flap.
BSI reboot instructions
www.206info.co.uk/Foru...eboot.html
dainbramaged01
PostPosted: Sun Apr 24, 2011 6:35 am Up
Ok another silly question but disconnect the BSI is there lead behin i jus unplug and that list doesnt state to reconnect it?
2.0hdi turbo
PostPosted: Sun Apr 24, 2011 6:37 am Up
Why you taking off the BSI to do a reboot Confused
Just disconnect the battery like it says in the guide.
Tell is the bank holiday and school hols
