Latest: tbafonso
Overall: 17130
Online Now [105]:
Visitors: 104
Today: 12773
Total: 103748592
Forums › The Car › 206 Talk › Bulbs
Bulbs
L18LTM
PostPosted: Thu Apr 28, 2011 12:46 am Up
i have crystal headlights, what bulbs do i need, im wanting to order some white light bulbs. are they both h7 ? + what size do i need for the side lights ? can they be swapped to L.E.D. thanks
**this is a post for a friend not the owner of this account **
-Dave-
PostPosted: Thu Apr 28, 2011 12:48 am Up
Trade Rating: +36
They are both H7 and the sidelight's can be swapped To LED, Most people recommend SMD 501.
Something like these,
cgi.ebay.co.uk/New-Xen...4157d1a1d7
Ex 206 Owner.
eddrj
PostPosted: Thu Apr 28, 2011 12:59 am Up
Both H7 headlight bulbs , sidelights 501 get LED's like above look much better .
Old car 2000/ 206 2.0 hdi.
PostPosted: Thu Apr 28, 2011 1:12 am Up
Why doesn't your friend signup? It's not like it's going to cost anything.
As said H7 55w, not 100w as you risk melting the headlamps and cables.
SMD led all the way.
PostPosted: Thu Apr 28, 2011 3:31 am Up
It will have H7 on top of the headlamp if your friend bothered to open the bonnet & actually have a look Wink
JE_180
PostPosted: Thu Apr 28, 2011 3:40 am Up
www.powerbulbs.com/pro...p?prod=180 I use these as my sidelight bulbs, expensive but worth the money tbh, looks sick with my HID's
doughboy5
PostPosted: Thu Apr 28, 2011 3:44 am Up
i have a 51 plate gti but it has crystals would that be h7 aswell or h4?
206 GTi
JE_180
PostPosted: Thu Apr 28, 2011 3:51 am Up
Do you have 1 bulb that operates as dipped/full beam? or do you have 2 separate ones?
PostPosted: Thu Apr 28, 2011 4:02 am Up
If your bulb has 2 pins then it is H7, 3 pins is H4, 1 pin H1.
As MrBSI said, it should listed on top of the headlamp.
auto-lites
PostPosted: Mon May 23, 2011 3:45 pm Up
Depending on the year but if its 2003 on then it should take H7 bulbs (2x pins on the base). We stock a variety of headlight bulbs for the 206 here at www.auto-lites.co.uk/s...rch&page=1
We also off 206info member discount. reply if interested an I cans end the voucher code.
meady
PostPosted: Mon May 23, 2011 3:57 pm Up
Trade Rating: +45
I have these for sale if intrested they have never been taken out of the box, and are still in the packaging that they got sent to me in, cheers
cgi.ebay.co.uk/2x-PHIL...3f02d6f555
TEAM - I HATE FACEBOOK Smile
PostPosted: Mon May 23, 2011 3:59 pm Up
Late 2003 when phase 2 came out is the cross over point, low spec early 2003 cars still rolled out the factory with the frosted H4 type headlights Wink
My feb 03 built 206 had frosted H4 headlamps when it rolled of the production line.
auto-lites
PostPosted: Mon May 23, 2011 4:04 pm Up
Yeah think you are right there. Always good to check what you have in the car/user manual also as sometimes the guides we have have some slight discrepencies. Anyhow whatever you need in terms of lighting, hosing, wipers etc we will stock in our store. As mentioned we can offer 206info members some discount.
PostPosted: Mon May 23, 2011 4:10 pm Up
For the 206 the bulb type needed is on top of the headlamp, unfortunately most people are to dam lazy to have a look Laughing
