Latest: Beduff1977
Overall: 17134
Online Now [394]:
Visitors: 393
Today: 10827
Total: 107191778
Forums › The Car › 206 Problems › preplex fuse.
preplex fuse.
PostPosted: Thu Apr 28, 2011 7:37 am Up
was going to remove the head unit, speakers (front and rear)
so might be better to remove the fuse too.
just read the manual saying 24/ 24B is the fuse for the audio, does that included everything (speakers+headunit?)
Abzynthe
PostPosted: Thu Apr 28, 2011 8:11 am Up
East Area Rep - Abzynthe
The speakers are just wired into the headunit, so I dont think they would have a separate fuse.
PostPosted: Thu Apr 28, 2011 8:16 am Up
ok that clears a bit up.
never understand how french do the wiring Laughing
PostPosted: Thu Apr 28, 2011 8:19 am Up
Luke wrote:
Engine Fuse Box
Fuse - Rating - Circuit Protected
MF1......70A......Built in Systems Interface supply
MF2......40A......Fan
MF3......-----......Additional heating
MF4......-----......Spare
MF8......70A.......Supply passenger comp. fuse box
MF9......50A.......Built in Systems Interface supply
MF10....40A.......Main and dipped beam
MF11....60A.......Supply passenger comp. fuse box (models with rear power windows)
MF12....50A.......Ignition switch power supply
MF13....40A.......Ignition switch power supply
MF19....30A.......ABS
MF17....30A.......ABS
F5......20/30A....Horn, sidelights, front foglight
F6......10/20A....Heated seats, heating, ventilation, running lights
F7......5/20A......Fan
F14....5/30A......Running lights, headlight wash, diagnostics socket
F18....----- .......Spare
F19....----- .......Spare
F20....----- .......Spare
F21....5A..........Coolant thermostat
F22....----- .......Spare
F23....5A..........ABS
F24....5A..........Engine Management, pre-heat unit, ventilation
F25....10A.........Fuel Pump
F26....10/30A....Engine management, fuel pump, oxygen sensor, EGR
F27....-----....... Engine management
F28....5A..........Throttle housing heater
F29....30A........Air pump
F30....10A........RH foglight, foglight warning light
F31....10A........LH foglight
F32....10A........Reverse light, speed sensor, diesel pump, auto gearbox, additional heating
F33....10A........Automatic gearbox
F34....5/15A.....oxygen sensor
Passenger Fuse Box (28 fuse)
F1......SH..........Pre tensioner unit, front and side airbags, BSI supply
F2......5A..........Instrument cluster
F3......----- ......Spare
F4......5A..........Built in systems interface (BSI)
F5......----- ......Spare
F6......5A..........Engine management control unit, immobiliser
F7......5A..........Spare
F8......10A........Coolant temp unit, instrument panel, hazard warning, clock, multi/funct display, courtesy light
F9......5A..........Built in systems interface (BSI)
F10....----- .......Spare
F11....10A.........LH stop light, high level stop light
F12....10A.........RH stop light
F13....----- .......Spare
F14....30A.........Rear electric windows
F15....20A......... Luggage compartment illumination, tow-bar supply
F16....----- .......Spare
F17....----- .......Spare
F18....10A.........Number plate light, lighter illumination, clock, multi/funct display, interior illum.
F19....5A...........Rear foglight
F21....----- .......Spare
F22....10A.........Glovebox light, map light, courtesy light, clock, instrument panel, sat-nav, rear electric windows, .........................rain sensor
F23....20A.........Cigar lighter
F24....15A.........Radio
F25....20A.........Windscreen wiper and rear wiper
F26....----- .......Spare
F27....5A...........Built in system interface (BSI)
F28....----- .......Spare
Passenger Fuse Box (12 fuse)
F29....10A.........LH main beam
F30....10A.........RH main beam, main beam warning light
F31....10A.........LH dipped beam
F32....10A.........RH dipped beam, dipped beam warning light
F33....5A...........Headlight wash
F34....10A.........LH side/tail light
F35....10A.........RH side/tail light
F36....----- .......Spare
F37....----- .......Coolant temperature unit
F38....5A...........Fan, pressostat
F39....----- .......
F40....20/40A....Heating, ventelation
Does just look like 24. Speakers aren't fused. Wink
PostPosted: Thu Apr 28, 2011 8:22 am Up
Laughing
did you post a reply just by reading the title? Laughing
i got the fuse list. it jusr doesn't mention anything about the speaker Laughing
PostPosted: Thu Apr 28, 2011 8:24 am Up
No I posted a comment, but its in the middle of the quote... Let me go edit it.. Laughing
Now edited. Wink
PostPosted: Thu Apr 28, 2011 8:28 am Up
ok so now problem solved Laughing
PostPosted: Thu Apr 28, 2011 8:29 am Up
Btw, Why? Weight saving?
PostPosted: Thu Apr 28, 2011 8:49 am Up
who need radio in a track car? Laughing
Twidly
PostPosted: Thu Apr 28, 2011 10:51 am Up
Don't touch fuses. Take it from a seasoned pro!
PostPosted: Thu Apr 28, 2011 11:20 am Up
why?
