Online Now [484]:
Visitors: 484
Today: 105549
Total: 105547500
Forums › Tuning, Modification & Legal › Project Cars › dums 206
dums 206
PostPosted: Thu Apr 14, 2011 9:18 am Up
Probs just a snapped cable mate
Clutches just dont 'go'
dumdum0910
PostPosted: Fri Apr 15, 2011 11:00 am Up
got the car back earlier and all seems fine Very Happy the man who toke the car for repair said that the cable had got to its full adjustment so had to replace the cable
dumdum0910
PostPosted: Sun Apr 17, 2011 3:00 am Up
just thought i would take another pic of how the car stands at the mo... no updates
dumdum0910
PostPosted: Tue Apr 19, 2011 1:33 pm Up
small update today. replaced the number plate bulbs for LED's
will get a better pic when it gets darker
dumdum0910
PostPosted: Thu Apr 21, 2011 7:40 am Up
some more update today.. started to spray the black trim in renault black gold paint around the car as the sun is out Very Happy
in primer
after lacquer
also got myself some 206 tailored mats from purgeot
dumdum0910
PostPosted: Fri Apr 22, 2011 12:48 pm Up
today sprayed the bonnet vents to match the black trims... pics dont really do the colour justice
PostPosted: Fri Apr 22, 2011 1:04 pm Up
did you do that with cans or spray gun?? made a bloody good job if it came from cans!!!
cars looking good btw
dumdum0910
PostPosted: Fri Apr 22, 2011 1:08 pm Up
cans.. (halfrauds paint ) many years of practice... 5 to be exact Razz
dumdum0910
PostPosted: Wed Apr 27, 2011 11:09 am Up
so more done today sprayed the centre console in the black to match the black trim around the car
just waiting for em to dry so i can refit them
dumdum0910
PostPosted: Wed Apr 27, 2011 11:49 am Up
all fitted
techy
PostPosted: Wed Apr 27, 2011 12:11 pm Up
very easy to get a finish like that out of cans if you take your time and do the prep properly and take your time when painting and just do light coats
the weather at the minute also helps
dumdum0910
PostPosted: Wed Apr 27, 2011 12:30 pm Up
as above all about the prep and light coats
dumdum0910
PostPosted: Fri Apr 29, 2011 12:46 pm Up
some more spray painting today Razz sprayed the speedo cluster
PostPosted: Sat Apr 30, 2011 3:07 am Up
well impressed can you give me a few pointers on how to get a finish that good then? Smile
dumdum0910
PostPosted: Sat Apr 30, 2011 3:30 am Up
rub the item down with wet and dry to give it a key and to smooth it. panel wipe to clean , light coats of colour i done 3 light coats of black and when the colour is tacky , almost dry do light coats with lacquer . leave to dry for atleast an hour to refit. if you want a perfect mirror shine wet and dry and lacquer and spray again . wait to dry and use G3 t-cut and polish
Page 2 of 4
