Posted: Mon May 09, 2011 1:13 pm |
just curious as i saw in another thread someone warning off NGK's wich mine has at the moment
When I serviced it they were the ones i was given. i did remove the bosch ones.
I have seen the four pin bosch ones online and considered them.
So what is the best to use?
thanks in advance folks...
Posted: Mon May 09, 2011 1:17 pm |
I'm not sure what's in mine at the min but I've got some Bosch super 4's waiting to go in when I get a spare hour or two
Posted: Mon May 09, 2011 1:21 pm |
Bosh super 4s.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
yeah there the ones im considering.
Posted: Mon May 09, 2011 1:23 pm |
Might as well get super plus, new technology
Posted: Mon May 09, 2011 1:26 pm |
Super 4s = engine failure I do not recommend then, have bits of ceramics come off under hard driving. Replaced for NGK laser platinums
Posted: Mon May 09, 2011 1:30 pm |
Lodey wrote: |
Super 4s = engine failure I do not recommend then, have bits of ceramics come off under hard driving. Replaced for NGK laser platinums  |
Mine have always been fine.
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
Don't use NGK on the 206 Lodey
Posted: Mon May 09, 2011 1:32 pm |
I've got some Denso things...from Euro Car Parts.
Posted: Mon May 09, 2011 1:34 pm |
Denso Iridiums are great plugs.
Posted: Mon May 09, 2011 1:35 pm |
what is the reason for not using NGK's? they break up or just missfire?
and what are the super plus?
Posted: Mon May 09, 2011 1:37 pm |
denso? heard them mentioned somewhere before.
anybody know the part number? or a site that sells them.
Posted: Mon May 09, 2011 1:40 pm |
Just search mate. This type of thread is created every day recently. Sick of repeating the same stuff
Posted: Mon May 09, 2011 1:44 pm |
Posted: Mon May 09, 2011 1:45 pm |
john_e88 wrote: |
Lodey wrote: |
Mine have always been fine. |
Fair enough then could be down to turbo and map, as for a gti it's a bit different, but as seb said denso iridiums are good
