Latest: tbafonso
Overall: 17130
Online Now [84]:
Visitors: 83
Today: 7916
Total: 104132720
Forums › The Car › 206 Talk › what sparkplugs are in your 206 gti?
Didz
PostPosted: Mon May 09, 2011 1:13 pm Up
just curious as i saw in another thread someone warning off NGK's wich mine has at the moment Shocked
When I serviced it they were the ones i was given. i did remove the bosch ones. Rolling Eyes
I have seen the four pin bosch ones online and considered them.
So what is the best to use?
thanks in advance folks...
Life's for living....
furryhobnob
PostPosted: Mon May 09, 2011 1:17 pm Up
I'm not sure what's in mine at the min but I've got some Bosch super 4's waiting to go in when I get a spare hour or two
NICKST
PostPosted: Mon May 09, 2011 1:21 pm Up
Bosh super 4s.
Didz
yeah there the ones im considering.
PostPosted: Mon May 09, 2011 1:23 pm Up
Might as well get super plus, new technology
Lodey
PostPosted: Mon May 09, 2011 1:26 pm Up
Super 4s = engine failure I do not recommend then, have bits of ceramics come off under hard driving. Replaced for NGK laser platinums Smile
Team: 20vT power
JE_180
PostPosted: Mon May 09, 2011 1:30 pm Up
Mine have always been fine.
Don't use NGK on the 206 Lodey Wink
PostPosted: Mon May 09, 2011 1:32 pm Up
I've got some Denso things...from Euro Car Parts.
Seb
PostPosted: Mon May 09, 2011 1:34 pm Up
Staff - Seb
Denso Iridiums are great plugs.
Didz
PostPosted: Mon May 09, 2011 1:35 pm Up
what is the reason for not using NGK's? they break up or just missfire?
and what are the super plus?
Didz
PostPosted: Mon May 09, 2011 1:37 pm Up
denso? heard them mentioned somewhere before.
anybody know the part number? or a site that sells them.
PostPosted: Mon May 09, 2011 1:40 pm Up
Just search mate. This type of thread is created every day recently. Sick of repeating the same stuff
Seb
PostPosted: Mon May 09, 2011 1:44 pm Up
Staff - Seb
cgi.ebay.co.uk/DENSO-I...4cf02cc6ef
That's for an individual plug. I'm sure you can get them for about a tenner each. They are good plugs, hence the price.
Lodey
PostPosted: Mon May 09, 2011 1:45 pm Up
Fair enough then could be down to turbo and map, as for a gti it's a bit different, but as seb said denso iridiums are good
Team: 20vT power
